makefile.
Matthew Knepley knepley at mcs.anl.gov
Fri Feb 17 14:06:29 CST 2006
billy at dem.uminho.pt writes:
> I am new to PETSc, so I don't really know how it works.
> I added this line to my makefile:
> include $(PETSC_DIR)/bmake/common/base
> but I had a target named 'clean' defined. Now, when I run my makefile it says:
> ... ignoring old commands for target 'clean'
> Does PETSc also define a target named 'clean'? If yes, what does it do?
  It does define 'clean' to cleanup up after compilation. You could change the name
of your target if you need it. I will look at changing it in an up coming release.
    Matt
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec Guiness
