DPETSC_USE_FORTRAN_KERNELS-warning
Patrick Lechner
mappol at gmail.com
Mon Aug 28 10:44:23 CDT 2006
Dear all,
I currently have the following problem and would be very grateful for any
useful advice:
I have written a Fortran code that uses PETSc for the solution of various
linear systems with complex entries (both in the stiffness matrix and in the
load vector). When I use the PETSc-Log to check the times for my runs, I get
the following warning:
# WARNING!!!
# The code for various complex numbers numerical
# kernels uses C++, which generally is not well
# optimized. For performance that is about 4-5 times
# faster, specify the flag -DPETSC_USE_FORTRAN_KERNELS #
# in base_variables and recompile the PETSc libraries.
My problem now is, that I can't find "base_variables" in my latest
PETSc-version (2.3.1-p15)...
Do I just add the flag to my cpp-flags in bmake/$PETSC_ARCH/petscconf? Or
should I do this modification somewhere else?
Thanks a lot for any help with this!
Best wishes,
Patrick
Patrick Lechner
Numerical Analysist / Numerical Modeller
Flat 1
159 Hardgate
Aberdeen, AB11 6XQ
Phone: 07815 927333
E-mail: patrick at lechner.com
Homepage: http://www.patrick.lechner.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060828/8d360eb3/attachment.htm>
