leave my rows alone
Satish Balay
balay at mcs.anl.gov
Wed Aug 16 11:25:15 CDT 2006
On Wed, 16 Aug 2006, Thomas Geenen wrote:
> dear petsc users,
> is there a way to prevent Petsc during the assembly phase from redistributing
> matrix rows over cpu's ??
The row distribution is done at matrix creation time - and you can set
the row distribution with MatSetSizes() [or MatCreateMPIAIJ() etc..]
by using the correct distribution value - instead of PETSC_DECIDE
> i like the way the rows are assigned to the cpu's during the
> setvalues phase.
I don't understand this statement. The row assignment doesn't change
> apparently petsc assigns the first nrows to cpu0 the second nrows to cpu1 etc.
yes. this fact can't be changed.
> I could of course renumber my matrix but I would rather convince
> petsc that it should keep the distribution of the matrix rows.
If you have some other global numbering scheme which is inconsitant
with the matrix row numbering scheme - then you can use 'AO' object
and associated routines to convert between mappings.
Note: 'row distribution' is different from 'row numbering'.
Satish
