profiling PETSc code
Matt Funk
mafunk at nmsu.edu
Tue Aug 15 15:35:52 CDT 2006
Do you want me to use the debug version or the optimized version of PETSc?
mat
On Tuesday 15 August 2006 13:56, Barry Smith wrote:
> Please send the entire -info output as an attachment to me. (Not
> in the email) I'll study it in more detail.
> Barry
> On Tue, 15 Aug 2006, Matt Funk wrote:
> > On Tuesday 15 August 2006 11:52, Barry Smith wrote:
> >>> MatSolve 16000 1.0 1.1285e+02 1.4 1.50e+08 1.4 0.0e+00
> >>> 0.0e+00
> >> balance
> >> Hmmm, I would guess that the matrix entries are not so well balanced?
> >> One process takes 1.4 times as long for the triangular solves as the
> >> other so either one matrix has many more entries or one processor is
> >> slower then the other.
> >> Barry
> > Well it would seem that way at first, but i don't know how that could be
> > since i allocate an exactly equal amount of points on both processor (see
> > previous email).
> > Further i used the -mat_view_info option. Here is what it gives me:
> > Matrix Object:
> > type=mpiaij, rows=119808, cols=119808
> > [1] PetscCommDuplicateUsing internal PETSc communicator 91 168
> > Matrix Object:
> > type=seqaij, rows=59904, cols=59904
> > total: nonzeros=407400, allocated nonzeros=407400
> > not using I-node routines
> > Matrix Object:
> > So to me it look s well split up. Is there anything else that somebody
> > can think of. The machine i am running on is all same processors.
> > By the way, i am not sure if the '[1] PetscCommDuplicateUsing internal
> > PETSc communicator 91 168' is something i need to worry about??
> > mat
> >>> Hi Matt,
> >>> sorry for the delay since the last email, but there were some other
> >>> things i needed to do.
> >>> Anyway, I hope that maybe I can get some more help from you guys with
> >>> respect to the loadimbalance problem i have. Here is the situtation:
> >>> I run my code on 2 procs. I profile my KSPSolve call and here is what i
> >>> get:
> >>> --- Event Stage 2: Stage 2 of ChomboPetscInterface
> >>> VecDot 20000 1.0 1.9575e+01 2.0 2.39e+08 2.0 0.0e+00
> >>> 0.0e+00 2.0e+04 2 8 0 0 56 7 8 0 0 56 245
> >>> VecNorm 16000 1.0 4.0559e+01 3.2 1.53e+08 3.2 0.0e+00
> >>> 0.0e+00 1.6e+04 3 7 0 0 44 13 7 0 0 44 95
> >>> VecCopy 4000 1.0 1.5148e+00 1.4 0.00e+00 0.0 0.0e+00
> >>> 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
> >>> VecSet 16000 1.0 3.1937e+00 1.8 0.00e+00 0.0 0.0e+00
> >>> VecAXPY 16000 1.0 8.2395e+00 1.4 3.22e+08 1.4 0.0e+00
> >>> 0.0e+00 0.0e+00 1 7 0 0 0 3 7 0 0 0 465
> >>> VecAYPX 8000 1.0 3.6370e+00 1.3 3.46e+08 1.3 0.0e+00
> >>> 0.0e+00 0.0e+00 0 3 0 0 0 2 3 0 0 0 527
> >>> VecScatterBegin 12000 1.0 5.7721e-01 1.1 0.00e+00 0.0 2.4e+04
> >>> 2.1e+04 0.0e+00 0 0100100 0 0 0100100 0 0
> >>> VecScatterEnd 12000 1.0 1.4059e+01 9.2 0.00e+00 0.0 0.0e+00
> >>> 0.0e+00 0.0e+00 1 0 0 0 0 4 0 0 0 0 0
> >>> MatMult 12000 1.0 5.0567e+01 1.0 1.82e+08 1.0 2.4e+04
> >>> 2.1e+04 0.0e+00 5 32100100 0 25 32100100 0 361
> >>> 0.0e+00 0.0e+00 10 43 0 0 0 47 43 0 0 0 214
> >>> MatLUFactorNum 1 1.0 1.9693e-02 1.0 5.79e+07 1.1 0.0e+00
> >>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 110
> >>> MatILUFactorSym 1 1.0 7.8840e-03 1.1 0.00e+00 0.0 0.0e+00
> >>> 0.0e+00 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >>> MatGetOrdering 1 1.0 1.2250e-03 1.1 0.00e+00 0.0 0.0e+00
> >>> 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >>> KSPSetup 1 1.0 1.1921e-06 1.2 0.00e+00 0.0 0.0e+00
> >>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >>> KSPSolve 4000 1.0 2.0419e+02 1.0 1.39e+08 1.0 2.4e+04
> >>> 2.1e+04 3.6e+04 21100100100100 100100100100100 278
> >>> PCSetUp 1 1.0 2.8828e-02 1.1 3.99e+07 1.1 0.0e+00
> >>> 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 75
> >>> PCSetUpOnBlocks 4000 1.0 3.5605e-02 1.1 3.35e+07 1.1 0.0e+00
> >>> 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 61
> >>> PCApply 16000 1.0 1.1661e+02 1.4 1.46e+08 1.4 0.0e+00
> >>> 0.0e+00 0.0e+00 10 43 0 0 0 49 43 0 0 0 207
> >>> Some things to note are the following:
> >>> I allocate my vector as:
> >>> VecCreateMPI(PETSC_COMM_WORLD, //communicator
> >>> a_totallocal_numPoints[a_thisproc], //local points on this proc
> >>> a_totalglobal_numPoints, //total number of global points
> >>> &m_globalRHSVector); //the vector to be created
> >>> where the vector a_totallocal_numPoints is :
> >>> a_totallocal_numPoints: 59904 59904
> >>> The matrix is allocated as:
> >>> m_ierr = MatCreateMPIAIJ(PETSC_COMM_WORLD, //communicator
> >>> a_totallocal_numPoints[a_thisproc], //total number of local rows
> >>> (that is rows residing on this proc
> >>> a_totallocal_numPoints[a_thisproc], //total number of columns
> >>> corresponding to local part of parallel vector
> >>> a_totalglobal_numPoints, //number of global rows
> >>> a_totalglobal_numPoints, //number of global columns
> >>> PETSC_NULL,
> >>> a_NumberOfNZPointsInDiagonalMatrix,
> >>> PETSC_NULL,
> >>> a_NumberOfNZPointsInOffDiagonalMatrix,
> >>> &m_globalMatrix);
> >>> With the info option i checked and there is no extra mallocs at all.
> >>> My problems setup is symmetric so it seems that everything is set up so
> >>> that it should be essentially perfectly balanced. However, the numbers
> >>> given above certainly do not reflect that.
> >>> However, the in all other parts of my code (except the PETSc call), i
> >>> get the expected, almost perfect loadbalance.
> >>> Is there anything that i am overlooking? Any help is greatly
> >>> appreciated.
> >>> thanks
> >>> mat
> >>> On Wednesday 02 August 2006 16:21, Matt Funk wrote:
> >>>> Hi Matt,
> >>>> It could be a bad load imbalance because i don't let PETSc decide. I
> >>>> need to fix that anyway, so i think i'll try that first and then let
> >>>> you know. Thanks though for the quick response and helping me to
> >>>> interpret those numbers ...
> >>>> mat
> >>>> On Wednesday 02 August 2006 15:50, Matthew Knepley wrote:
> >>>>> On 8/2/06, Matt Funk <mafunk at nmsu.edu> wrote:
> >>>>>> Hi Matt,
> >>>>>> thanks for all the help so far. The -info option is really very
> >>>>>> helpful. So i think i straightened the actual errors out. However,
> >>>>>> now i am back to the original question i had. That is why it takes
> >>>>>> so much longer on 4 procs than on 1 proc.
> >>>>> So you have a 1.5 load imbalance for MatMult(), which probably
> >>>>> cascades to give the 133! load imbalance for VecDot(). You probably
> >>>>> have either:
> >>>>> 1) VERY bad laod imbalance
> >>>>> 2) a screwed up network
> >>>>> 3) bad contention on the network (loaded cluster)
> >>>>> Can you help us narrow this down?
> >>>>> Matt
> >>>>>> I profiled the KSPSolve(...) as stage 2:
> >>>>>> For 1 proc i have:
> >>>>>> VecDot 4000 1.0 4.9158e-02 1.0 4.74e+08 1.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 0 18 0 0 0 2 18 0 0 0 474
> >>>>>> VecNorm 8000 1.0 2.1798e-01 1.0 2.14e+08 1.0 0.0e+00
> >>>>>> 0.0e+00 4.0e+03 1 36 0 0 28 7 36 0 0 33 214
> >>>>>> VecAYPX 4000 1.0 1.3449e-01 1.0 1.73e+08 1.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 0 18 0 0 0 5 18 0 0 0 173
> >>>>>> MatMult 4000 1.0 3.6004e-01 1.0 3.24e+07 1.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 1 9 0 0 0 12 9 0 0 0 32
> >>>>>> MatSolve 8000 1.0 1.0620e+00 1.0 2.19e+07 1.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 3 18 0 0 0 36 18 0 0 0 22
> >>>>>> KSPSolve 4000 1.0 2.8338e+00 1.0 4.52e+07 1.0 0.0e+00
> >>>>>> 0.0e+00 1.2e+04 7100 0 0 84 97100 0 0100 45
> >>>>>> PCApply 8000 1.0 1.1133e+00 1.0 2.09e+07 1.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 3 18 0 0 0 38 18 0 0 0 21
> >>>>>> for 4 procs i have :
> >>>>>> VecDot 4000 1.0 3.5884e+01133.7 2.17e+07133.7 0.0e+00
> >>>>>> 0.0e+00 4.0e+03 8 18 0 0 5 9 18 0 0 14 1
> >>>>>> VecNorm 8000 1.0 3.4986e-01 1.3 4.43e+07 1.3 0.0e+00
> >>>>>> 0.0e+00 8.0e+03 0 36 0 0 10 0 36 0 0 29 133
> >>>>>> VecSet 8000 1.0 3.5024e-02 1.4 0.00e+00 0.0 0.0e+00
> >>>>>> VecAYPX 4000 1.0 5.6790e-02 1.3 1.28e+08 1.3 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 0 18 0 0 0 0 18 0 0 0 410
> >>>>>> VecScatterBegin 4000 1.0 6.0042e+01 1.4 0.00e+00 0.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 38 0 0 0 0 45 0 0 0 0 0
> >>>>>> VecScatterEnd 4000 1.0 5.9364e+01 1.4 0.00e+00 0.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 37 0 0 0 0 44 0 0 0 0 0
> >>>>>> MatMult 4000 1.0 1.1959e+02 1.4 3.46e+04 1.4 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 75 9 0 0 0 89 9 0 0 0 0
> >>>>>> MatSolve 8000 1.0 2.8150e-01 1.0 2.16e+07 1.0 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 0 18 0 0 0 0 18 0 0 0 83
> >>>>>> MatLUFactorNum 1 1.0 1.3685e-04 1.1 5.64e+06 1.1 0.0e+00
> >>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 21
> >>>>>> MatILUFactorSym 1 1.0 2.3389e-04 1.2 0.00e+00 0.0 0.0e+00
> >>>>>> MatGetOrdering 1 1.0 9.6083e-05 1.2 0.00e+00 0.0 0.0e+00
> >>>>>> KSPSetup 1 1.0 2.1458e-06 2.2 0.00e+00 0.0 0.0e+00
> >>>>>> KSPSolve 4000 1.0 1.2200e+02 1.0 2.63e+05 1.0 0.0e+00
> >>>>>> 0.0e+00 2.8e+04 84100 0 0 34 100100 0 0100 1
> >>>>>> PCSetUp 1 1.0 5.0187e-04 1.2 1.68e+06 1.2 0.0e+00
> >>>>>> 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 6
> >>>>>> PCSetUpOnBlocks 4000 1.0 1.2104e-02 2.2 1.34e+05 2.2 0.0e+00
> >>>>>> 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
> >>>>>> PCApply 8000 1.0 8.4254e-01 1.2 8.27e+06 1.2 0.0e+00
> >>>>>> 0.0e+00 8.0e+03 1 18 0 0 10 1 18 0 0 29 28
> >>>>>> Now if i understand it right, all these calls summarize all calls
> >>>>>> between the pop and push commands. That would mean that the majority
> >>>>>> of the time is spend in the MatMult and in within that the
> >>>>>> VecScatterBegin and VecScatterEnd commands (if i understand it
> >>>>>> right).
> >>>>>> My problem size is really small. So i was wondering if the problem
> >>>>>> lies in that (namely that the major time is simply spend
> >>>>>> communicating between processors, or whether there is still
> >>>>>> something wrong with how i wrote the code?)
> >>>>>> thanks
> >>>>>> mat
> >>>>>> On Tuesday 01 August 2006 18:28, Matthew Knepley wrote:
> >>>>>>> On 8/1/06, Matt Funk <mafunk at nmsu.edu> wrote:
> >>>>>>>> Actually the errors occur on my calls to a PETSc functions after
> >>>>>>>> calling PETSCInitialize.
> >>>>>>> Yes, it is the error I pointed out in the last message.
> >>>>>>> Matt
> >>>>>>>> mat
