How to loop Petsc in Fortran?
Letian Wang letian.wang at ghiocel-tech.com
Mon Apr 24 11:56:36 CDT 2006
Dear All:
Question 1):
For an optimization task, I need to loop Petsc (I'm using Petsc-2.3.0). But
I had problems to reinitialize Petsc after finalize, here is a simple
FORTRAN program to explain my problem:
      program petsc_test
#     include "include/finclude/petsc.h"
      call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
      call PetscFinalize(ierr)
      print*,'ierr=',ierr
      end
When the program excuted to the second PetscInitial line, it shows error
message: "Error encountered before initializing MPICH". Can anyone help me
on this? Thanks.
Question 2):
Follow up my previous question, I also tried to Initiallize and Finalize
Petsc only once and perform the do-loop between Petscinitialize and
PetscFinalize. I used KSP CR solver with Prometheus PCs to solver large
linear equations. After several loops, the program was interrupted by
segmentation violation error. I suppose there was a memory leak somewhere.
The error message is like this: Any suggestion for this? Thanks
*********Doing job -- nosort0001
Task No.    1    Total CPU=       52.3
 *********Doing job -- nosort0002
Task No.    2    Total CPU=       52.1
 *********Doing job -- nosort0003
Petsc Release Version 2.3.0, Patch 44, April, 26, 2005
See docs/changes/index.html for recent updates.
See docs/faq.html for hints about trouble shooting.
See docs/index.html for manual pages.
../feap on a linux-gnu named GPTnode3.cl.ghiocel-tech.com by ltwang Mon Apr
24 15:25:04 2006
Libraries linked from /home/ltwang/Library/petsc-2.3.0/lib/linux-gnu
Configure run at Tue Mar 14 11:19:49 2006
Configure options --with-mpi-dir=/usr --with-debugging=0
--download-spooles=1 --download-f-blas-lapack=1 --download-parmetis=1
--download-prometheus=1 --with-shared=0
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[1]PETSC ERROR: to get more information on the crash.
[1]PETSC ERROR: User provided function() line 0 in unknown directory unknown
file
[1]PETSC ERROR: Signal received!
[1]PETSC ERROR:  !
[cli_1]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
[cli_0]: aborting job:
Fatal error in MPI_Allgather: Other MPI error, error stack:
MPI_Allgather(949)........................: MPI_Allgather(sbuf=0xbffeea14,
scount=1, MPI_INT, rbuf=0x8bf0a0c, rcount=1, MPI_INT, comm=0x84000000)
failed
MPIR_Allgather(180).......................:
MPIC_Sendrecv(161)........................:
MPIC_Wait(321)............................:
MPIDI_CH3_Progress_wait(199)..............: an error occurred while handling
an event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(422):
MPIDU_Socki_handle_read(649)..............: connection failure
(set=0,sock=2,errno=104:(strerror() not found))
rank 1 in job 477  GPTMaster_53830   caused collective abort of all ranks
  exit status of rank 1: return code 59
Letian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060424/d5957cda/attachment.htm>
