what is default ordering method
Matthew Knepley
knepley at gmail.com
Sat Apr 8 13:42:19 CDT 2006
On 4/8/06, buket at be.itu.edu.tr <buket at be.itu.edu.tr> wrote:
> Hi,
> I have several questions;
> Which ordering method does petsc use by default before matrix
> factorization?
None, but external packages may use a default ordering.
How can I change the restarted value of Gmres(m)?
-ksp_gmres_restart
Is there any parallel overhead when I run petsc program on single
> processor (with mprun -np 1)?
Not normally, since all classes are Seq by default.
Matt
Thank you,
> Best Regards,
> Buket Benek
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060408/4b8250a8/attachment.htm>
