[Petsc-trilinos-discussion] Scope and requirements
    Bartlett, Roscoe A.
    bartlettra at ornl.gov
    Fri Nov 22 19:41:19 CST 2013
So what? If it solves a problem, what is it to us what a client application does? The problem is that there should be no link ordering reqiirement between trilinos and petsc. What if trilinos had adapters for petsc solvers and preconditioners (like was supposed to happen in tops-2 ), how would that work (that is called a circular dependency)? With C++ we could just put in static initialization code in downstream lib to insert adapter automatically but there should really be an independent package outside of both that provides trilinos and petsc interoperability and that solves the ordering problem.
-Ross
-----Original Message-----
From: Barry Smith [bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>]
Sent: Friday, November 22, 2013 08:02 PM Eastern Standard Time
To: Bartlett, Roscoe A.
Cc: Jed Brown; Matthew Knepley; petsc-trilinos-discussion at lists.mcs.anl.gov
Subject: Re: [Petsc-trilinos-discussion] Scope and requirements
On Nov 22, 2013, at 6:48 PM, Bartlett, Roscoe A. <bartlettra at ornl.gov> wrote:
> Then what is the issue with shared vs static libs? Why can't downstream client app just compile the petsc ml adapter, call the registration func then use ml under petsc like before?
   They can. Our objection to this is
> call the registration func.
    Barry
> -Ross
> From: Jed Brown [jedbrown at mcs.anl.gov]
> Sent: Friday, November 22, 2013 06:44 PM Eastern Standard Time
> To: Matthew Knepley; Bartlett, Roscoe A.
> Cc: Barry Smith; petsc-trilinos-discussion at lists.mcs.anl.gov
> Matthew Knepley <knepley at gmail.com> writes:
> > http://en.wikipedia.org/wiki/Dependency_injection Yes, we use plugins in
> > exactly the same way. They obey the top-level interface,
> > just like your Stratimikos interfaces, and we instantiate the concrete type
> > dynamically (we can load the appropriate DLL with a
> > runtime option if necessary). It has been this way since I was in grad
> > school in 1996.
> PETSc's system is closer to what Martin Fowler refers to as "service
> locator" in his essay which seems to be a popular reference, though the
> techniques had been around for decades by the time he wrote the essay.
> http://www.martinfowler.com/articles/injection.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-trilinos-discussion/attachments/20131122/0ec625cc/attachment.html>
More information about the Petsc-trilinos-discussion
