[Petsc-trilinos-discussion] Scope and requirements
Bartlett, Roscoe A.
bartlettra at ornl.gov
Fri Nov 22 12:49:21 CST 2013
> "Bartlett, Roscoe A." <bartlettra at ornl.gov> writes:
> > ML gets built along with the rest of Trilinos as a TriBITS package in
> > VERA where PETSc is treated as a pre-built static TPL. This is done
> > because changes are being made to Trilinos to drive CASL work but not
> > for PETSc. Building PETSc downstream from Trilinos would mean
> > wrapping PETSc as a TriBITS package and we don't want to go there
> > unless we are forced to do so.
> Sounds like a build system limitation. Prometheus was a heavy user of
> PETSc, but --download-prometheus still set things up properly and
> registered it as a PC without needing client applications to add
> work-arounds.
[Bartlett, Roscoe A.] Does the PETSc build system support 100% correct automatic incremental rebuilds when upstream dependencies for these downloaded packages change? Does it do a 100% correct incremental rebuild when just a few files in the downloaded package change? That is the problem. Anyone can create a build system that does a one pass configure, build, and install from scratch. The problem is supporting an efficient development process where bits and pieces are incrementally changing. We take that for grated in a unified CMake system.
-Ross
More information about the Petsc-trilinos-discussion
