[Petsc-trilinos-discussion] Scope and requirements
Matthew Knepley
knepley at gmail.com
Thu Nov 21 13:06:50 CST 2013
On Thu, Nov 21, 2013 at 12:55 PM, Bartlett, Roscoe A.
<bartlettra at ornl.gov>wrote:
> Matt,
I have read your slides. I think what we propose, using only the latest
version, does indeed do what you want:
- Prepare users for the break in backward compatibility
- We tell the users when we are releasing and post the Changes list
months prior. They can also look at the master branch.
I consider this far better than "deprecated" warnings.
- Fail big and hard when backward compatibility is dropped
- We do. Configure fails if you do not have what we are looking for.
- Provide for safe straightforward upgrades
- Since everything is already behind our interface, there are no user
code changes.
I would add that in the case of ML its particularly easy, since there is a
drop-in replacement (GAMG).
Matt
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
> *Sent:* Thursday, November 21, 2013 1:46 PM
> *To:* Bartlett, Roscoe A.
> *Cc:* Jed Brown; Barry Smith; petsc-trilinos-discussion at lists.mcs.anl.gov
> *Subject:* Re: [Petsc-trilinos-discussion] Scope and requirements
> On Thu, Nov 21, 2013 at 12:39 PM, Bartlett, Roscoe A. <bartlettra at ornl.gov>
> wrote:
> > > Therefore, I would say that before there is any talk of more detailed
> > > interfaces or interoperability between Trilinos and PETSc that we
> > > first solve the basic problems of version compatibility,
> > PETSc and Trilinos have a different approach to interface evolution. We
> > tend to make minor modifications each year while you tend to create
> > entirely new interfaces and coax applications over to the new ones. The
> > need to upgrade inflicts some pain on the users, but our users have
> > always ultimately buckled down and done it.
> [Bartlett, Roscoe A.]
> But the compatibility between Trilinos and PETSc, say in the PETSc/ML case
> has nothing to do with the "user" (i.e. downstream project using Trilinos
> and PETSc). Can they just grab arbitrary versions of PETSC and Trilinos
> and configure and build them and have the ML support under PETSc work? If
> not arbitrary versions (which is unreasonable) what about ranges of
> versions? Think about this same issue in a large ecosystem of libraries
> and applications in a large multi-physics coupled code (CASL VERA is a
> small example of this we have already had to face). For example, if every
> major release of Library A breaks backward compatibility with prior
> versions and you have to couple together three APPs that all use three
> different versions of Library A in a statically linked executable, how can
> that work? Do you just tell all the APP development teams to all upgrade
> (or downgrade) to the use same version of Library A that has different
> interfaces and behavior between the different v
> ersions? Is that practical? What if the downstream project development
> team does even have access to the developers of say APP1 that currently
> only works against an older version of Library A? Does the downstream
> project development team take it upon themselves to upgrade the version of
> Library A (with new interfaces and behavior) in APP1 that they did not even
> develop and don't really understand all the test cases for
> We support the latest version of a package. Nothing else. Any other
> strategy is just not feasible.
> *[Bartlett, Roscoe A.] Supporting the latest version is *not* the issue. *That
> does not answer the basic question. How can we expect projects to couple
> two, three, or more APPs that all use different incompatible versions of
> the same library? What is the answer? If a library maintains a longer
> window of backward compatibility for more mature features, you only have to
> support the latest version and yet still allow all different kinds of
> coupling and integration models. Please keep an open mind and read the
> balanced proposal for “Regulated Backward Compatibility” in the below
> reference. I don’t see any other way to achieve broader usage and
> acceptance of our software in a larger ecosystem of software and projects.
> If you see another way, I would like to know what it is.
> However, if Library A maintains sufficient backward compatibility between
> the ranges of versions of Library A currently in use by all three APP
> codes, then you just need to use the latest version of Library A and that
> is it. Easy as pie. This example, by the way, is shown in slides 36 and
> 37 in
> http://web.ornl.gov/~8vt/ORNLCSMDTribitsLifecycleModelPresentation.pdf.
> For those interested in the deeper arguments, I would recommend the
> section on "Regulated Backward Compatibility" in:
> http://web.ornl.gov/~8vt/TribitsLifecycleModel_v1.0.pdf
> which also describes the general three APP scenario mentioned above.
> Cheers,
> -Ross
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-trilinos-discussion/attachments/20131121/04a6ab40/attachment.html>
More information about the Petsc-trilinos-discussion
