[petsc-dev] Expectations for lock usage in PETSc
    Jed Brown
    jed at jedbrown.org
    Mon Sep  8 18:18:57 CDT 2025
Read locks can nest, but writable locks cannot.
The code here could have called VecLockWriteSet(y, PETSC_TRUE) and then released it. Arguably that would be more correct, though it does require a matching line of code and the writable access does not outlive the function. It also would the x == y logic to be reworked because the simpler functions can't be called when a write lock is held.
IMO, it would be great if the compiler could enforce that arguments are not aliased, but C doesn't provide a way to do that and forbidding it would have ripple effects.
Satish Balay <balay.anl at fastmail.org> writes:
> I see the initial change was at:
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/commit/d9ca1df42eda25bc875149d6d493aad6e204c9ff__;!!G_uCfscf7eWS!axSTcfB_iW7kKJe0hb14ApkNvXzHZBDqzONfz8eP0TVZNPqaBKoS2fxZhoUWUBKQk8RQpEVrly41e_Pt-04eizfoQw$
> And then refined at:
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/commit/8860a1345bb13588f3290163e72ce904901dbfb9__;!!G_uCfscf7eWS!axSTcfB_iW7kKJe0hb14ApkNvXzHZBDqzONfz8eP0TVZNPqaBKoS2fxZhoUWUBKQk8RQpEVrly41e_Pt-04ysS1gxw$
> Satish
> On Mon, 8 Sep 2025, Hovland, Paul via petsc-dev wrote:
>> Dear PETSc developers:
>> We have a question about the (expected) use of read and write locks in the PETSc implementation of vectors. If one looks at the implementation of VecAXPY in rvector.c (or, really, the implementation of VecAXPYAsync_Private, which is called by VexAXPY), it first calls
>>       PetscCall(VecSetErrorIfLocked(y, 1));
>> then calls
>>       PetscCall(VecLockReadPush(x));
>> then dispatches the AXPY method, followed by
>>       PetscCall(VecLockReadPop(x));
>> We’re curious why it just checks whether y is locked but goes through the whole locking and unlocking process for x. It seems like one should either also lock y or one could simply check whether there is a write lock on x, without having to go through the whole push/pop sequence.
>> Is it written this way because the easiest way to check whether x has a write lock on it (and throw an error if it does)  is to call VecLockReadPush? Is this pattern a relic of when PETSc implemented locks differently? Is there some other reason for the “inconsistent” (to our minds) handling of x and y?
>> Thanks,
>> Paul & Steve
