[petsc-dev] Additive Schwarz Method + ILU on GPU platforms
Angus, Justin Ray angus1 at llnl.gov
Wed Nov 5 17:01:34 CST 2025
Hi Barry,
Thanks for the explanation, though I’m not sure I understand exactly what it’s doing. I at least understand now that the overlap doesn’t simply include degrees of freedom from neighboring cells within the range of the specified overlap for each side and direction (which is how chat GPT told me it worked).
For this problem ASM with overlap 16 + LU for the sub pc gave optimal performance. A lower value for the overlap results in too many GMRES iterations. I’m actually surprised that such a large overlap was needed, because the code I’m using is nearly identical to another and in that code the GMRES iterations stay low with an overlap of 4. Perhaps there is something different in the setup that is not clear.
The PETSc preconditioners seem very powerful, bu it is difficult and time-consuming to find the optimal setup for a given problem given my nascent understanding of how the preconditoners work. Is there someone from PETSc (perhaps yourself) with advanced knowledge of the preconditions that I could schedule a zoom/webex meeting with to discuss?
Thanks!
-Justin
Date: Wednesday, November 5, 2025 at 2:48 PM
To: Angus, Justin Ray <angus1 at llnl.gov>
Cc: MFAdams at LBL.GOV <MFAdams at LBL.GOV>, Matthew Knepley <knepley at gmail.com>, petsc-dev at mcs.anl.gov <petsc-dev at mcs.anl.gov>
Subject: Re: [petsc-dev] Additive Schwarz Method + ILU on GPU platforms
  An overlap of 16 is huge and would rarely if ever, be done in practice. It is not surprising that the subproblems become as large as they do with such a large overlap.
  How the overlap is used.
  while (overlap--) {
     add to the subproblem all degrees of freedom that are coupled by nonzeros in the matrix to all the current degrees of freedom in the subproblem.
  So it is grabbing all the neighbors for 16 rounds of grabbing.
On Nov 5, 2025, at 3:05 PM, Angus, Justin Ray via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
I think the issue is my overlap is too large. Perhaps I don’t fully understand how the overlap parameter is used. Let me explain my setup below.
My vector of unknowns is the electric field on a Yee grid in a 2D geometry. I’m using 4x4 grid cells per rank. This gives 4*5 = 20 degrees of freedom for each of the two in-plane components of E, and 5*5 = 25 for the out-of-plane component. The total is 65 degrees of freedom per rank. My global problem size is 224x16 on 224 ranks for one case, and 224x32 on 448 ranks for another. Using ASM overlap 4, I get the following for PC sub blocks on a rank:
PC Object: (sub_) 1 MPI process
      type: lu
        out-of-place factorization
        Reusing fill from past factorization
        Reusing reordering from past factorization
        tolerance for zero pivot 2.22045e-14
        matrix ordering: nd
        factor fill ratio given 5., needed 4.02544
          Factored matrix follows:
            Mat Object: (sub_) 1 MPI process
              type: seqaij
              rows=402, cols=402
              package used to perform factorization: petsc
              total: nonzeros=16295, allocated nonzeros=16295
                not using I-node routines
The above is for a 224x16 size domain in 224 total ranks, but I get the same thing for a 224x32 size domain on 448 ranks, which is what I am expected to get.
However, if I set the overlap to 16 (which is larger than by box size on a given rank), I get the following
224x16 gid on 112 ranks:
      type: lu
        matrix ordering: nd
        factor fill ratio given 5., needed 6.52557
              type: seqaij
              rows=1316, cols=1316
              total: nonzeros=95195, allocated nonzeros=95195
      type: lu
        matrix ordering: nd
        factor fill ratio given 5., needed 8.59182
              type: seqaij
              rows=2632, cols=2632
              total: nonzeros=250675, allocated nonzeros=250675
In this case, with an overlap much larger than the box size, the rows/cols per rank go up by a factor of 2 when doubling the problem size at fixed work per rank.
Why is this?
How exactly is the overlap parameter used?
Thank you.
-Justin
Date: Wednesday, November 5, 2025 at 8:17 AM
To: MFAdams at LBL.GOV <MFAdams at LBL.GOV>, Matthew Knepley <knepley at gmail.com>
Cc: petsc-dev at mcs.anl.gov <petsc-dev at mcs.anl.gov>
Thanks for the reply.
The work per block should be the same for the weak scaling. I know LU is not scalable with respect to the block size.
Perhaps our setup is not doing what we think it is doing. I’ll look into it further.
-Justin
Date: Wednesday, November 5, 2025 at 6:14 AM
To: Matthew Knepley <knepley at gmail.com>
Cc: Angus, Justin Ray <angus1 at llnl.gov>, petsc-dev at mcs.anl.gov <petsc-dev at mcs.anl.gov>
And we do not have sparse LU on GPUs so that is done on the CPU.
And I don't know why it would not weak scale well.
Your results are consistent with just using one process with one domain, (re Matt) while you double the problem size.
On Tue, Nov 4, 2025 at 2:27 PM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, Nov 4, 2025 at 1:25 PM Angus, Justin Ray via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Hi Junchao,
We have recently been using ASM + LU for 2D problems on both CPU and GPU. However, I found that this method has very bad weak scaling. I find that the cost of PCApply increases by about a factor of 4 each time I increase the problem size in 1 dimension by a factor of 2 while keeping the load per core/gpu the same. The total number of GMRES iterations does not increase, just the cost of PCApply (and PCSetup). Is this scaling behavior expected? Any ideas of how to optimize the preconditioner?
The cost of PCApply for ASM is dominated by the cost of process-local block solves. You are using LU for the block solve. (Sparse) LU has cost roughly O(N^2) for the apply (depending on the structure of the matrix). So, if you double the size of a local block, your runtime should increase by about 4x. Thus LU is not a scalable method.
     Matt
Thank you.
-Justin
From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
Date: Monday, April 14, 2025 at 7:35 PM
To: Angus, Justin Ray <angus1 at llnl.gov<mailto:angus1 at llnl.gov>>
Cc: petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov> <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>>, Ghosh, Debojyoti <ghosh5 at llnl.gov<mailto:ghosh5 at llnl.gov>>
Petsc supports ILU0/ICC0 numeric factorization (without reordering) and then triangular solve on GPUs. It is done by calling vendor libraries (ex. cusparse).
We have options -pc_factor_mat_factor_on_host <bool>  -pc_factor_mat_solve_on_host <bool> to force doing the factorization and MatSolve on the host for device matrix types.
You can try to see if it works for your case.
--Junchao Zhang
On Mon, Apr 14, 2025 at 4:39 PM Angus, Justin Ray via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Hello,
A project I work on uses GMRES via PETSc. In particular, we have had good successes using the Additive Schwarz Method + ILU preconditioner setup using a CPU-based code. I found online where it is stated that “Parts of most preconditioners run directly on the GPU” (https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fqU8d4-9yvbQ0fiIAwK_ERRRExegWyVOrDZ3tImfMDlCnSMRLF9tQAAFhMDxk9Rt5DGS_zSPhi_UDwTuLGUW9Q$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bw6qeKcY7MKSvlEgcogdKR7fpjZSOFvka6zfDprUZ_sJHdE-YZmRD6UTqWQW3_uGVBII4P-AG0zaGTLbI67_fQ$>). Is ASM + ILU also available for GPU platforms?
-Justin
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fqU8d4-9yvbQ0fiIAwK_ERRRExegWyVOrDZ3tImfMDlCnSMRLF9tQAAFhMDxk9Rt5DGS_zSPhi_UDwTnsl7O9g$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dXQeQOf4ckc4MRP64tltlc6e1FJgPXuEuzX8tHsTreO_vIP2Lbge1es994i-WdQTd1zpmNP2R9dbEHfLa0v_$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20251105/86e39943/attachment-0001.html>
