[petsc-dev] Additive Schwarz Method + ILU on GPU platforms
Angus, Justin Ray angus1 at llnl.gov
Tue Nov 4 12:25:14 CST 2025
Hi Junchao,
We have recently been using ASM + LU for 2D problems on both CPU and GPU. However, I found that this method has very bad weak scaling. I find that the cost of PCApply increases by about a factor of 4 each time I increase the problem size in 1 dimension by a factor of 2 while keeping the load per core/gpu the same. The total number of GMRES iterations does not increase, just the cost of PCApply (and PCSetup). Is this scaling behavior expected? Any ideas of how to optimize the preconditioner?
Thank you.
-Justin
Date: Monday, April 14, 2025 at 7:35 PM
To: Angus, Justin Ray <angus1 at llnl.gov>
Cc: petsc-dev at mcs.anl.gov <petsc-dev at mcs.anl.gov>, Ghosh, Debojyoti <ghosh5 at llnl.gov>
Subject: Re: [petsc-dev] Additive Schwarz Method + ILU on GPU platforms
Petsc supports ILU0/ICC0 numeric factorization (without reordering) and then triangular solve on GPUs. It is done by calling vendor libraries (ex. cusparse).
We have options -pc_factor_mat_factor_on_host <bool>  -pc_factor_mat_solve_on_host <bool> to force doing the factorization and MatSolve on the host for device matrix types.
You can try to see if it works for your case.
--Junchao Zhang
On Mon, Apr 14, 2025 at 4:39 PM Angus, Justin Ray via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
Hello,
A project I work on uses GMRES via PETSc. In particular, we have had good successes using the Additive Schwarz Method + ILU preconditioner setup using a CPU-based code. I found online where it is stated that “Parts of most preconditioners run directly on the GPU” (https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!f0XJWVP6elKNdUG2AClFI5dyf1itzs2_b-_J60xUiPOON5oStGYegI8F9z6lgw0ucidOPXX5_OhJ628dK3vGJQ$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bw6qeKcY7MKSvlEgcogdKR7fpjZSOFvka6zfDprUZ_sJHdE-YZmRD6UTqWQW3_uGVBII4P-AG0zaGTLbI67_fQ$>). Is ASM + ILU also available for GPU platforms?
-Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20251104/6e51b83d/attachment.html>
