[petsc-dev] NumFocus questions
    Barry Smith
    bsmith at petsc.dev
    Wed May 28 14:19:48 CDT 2025
  I had the NumFocus meeting today and have two questions for discussion and eventual answer
1) Regarding the previous Code of Conduct question. I now understand the code of conduct questions we should answer
       1) Will PETSc keep its own C of C or replace it with the NumFocus C of C?  https://urldefense.us/v3/__https://numfocus.org/code-of-conduct__;!!G_uCfscf7eWS!Y44LznSZZaYg645FTg__j20tQtMybKiMIeoNRBkqz-bwT6u0nZ48BBKucvD5fAWUbB20ZOLJFlusrgmGlurC4w$  NumFocus
            has an outside group to investigate violations.
        2) If PETSc adopts the NumFocus C of C do we decide
            a) the outside group makes "recommendations" to the PETSc governance board if problems come up
            b) the outside group also imposes changes if a violation has occurred (XXX is banned from GitLab issues due to violations)?
            It is hard to see much practical difference between a and b, since no one can forcibly impose changes IMHO.
    We should ideally have a PETSc governance board decision by September.
 2) We need another "official" (one or more) PETSc contact for NumFocus. In case I die or am cancer ridden etc. Ideally, they would go to
      the annual meeting and meet with NumFocus a couple of times of year etc, like I do. It is a low-maintenance role unless you want it to be more.
      I nominate Jed (as one of them) since he was the instigator of PETSc joining NumFocus and understands it better than the rest of us.
      Volunteers?
Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250528/83ee1b01/attachment.html>
