[petsc-dev] Petsc cannot be configure
    David Jiawei LUO LIANG
    12431140 at mail.sustech.edu.cn
    Tue Jun 10 02:23:43 CDT 2025
Yes, the problem came from the compatibility between xcode, version of MacOS.
At first, my MacOS system is 15.1. Then, I upgraded it to 15.5. And the issues occured because I forgot to upgrade the xcode
(not only upgrade, but need to reinstall). This is the reason why there were issues between MPI and gcc. So, I reinstalled the xcode,
but there were a bug that the name of the sdk (updration modified the name of MacOS15.1.sdk as MacOS15.5.sdk ) such that the vtk
petsc linking cannot find the correct openGL path. I solved the issue just directly change the name back to MacOS15.1.sdk
南方科技大学/学生/研究生/2024
广东省深圳市南山区学苑大道1088号
------------------ Original ------------------
Date:  Mon, Jun 9, 2025 10:53 PM
To:  "Matthew Knepley"<knepley at gmail.com>;
Cc:  "David Jiawei LUO LIANG"<12431140 at mail.sustech.edu.cn>; "petsc-dev"<petsc-dev at mcs.anl.gov>;
Subject:  Re: [petsc-dev] Petsc cannot be configure
 Also use latest petsc version
There have been issues since xcode v15 - and various versions of pkgs (petsc, mpich etc) - required different workarounds.
Latest petsc, mpich should work well with latest xcode - without requiring these workarounds.
[and this MPICH is likely compiled with older xcode version - and hence is having issues with currently used xcode
Satish
Executing: /Users/lawkawai/lib/mpich-4.2.3-opt/bin/mpicc --version
stdout:
Apple clang version 16.0.0 (clang-1600.0.26.6)
Target: arm64-apple-darwin24.1.0
Executing: /Users/lawkawai/lib/mpich-4.2.3-opt/bin/mpicc -show
stdout: gcc -Wl,-ld_classic -Wl,-commons,use_dylibs -I/Users/lawkawai/lib/mpich-4.2.3-opt/include -L/Users/lawkawai/lib/mpich-4.2.3-opt/lib -lmpi -lpmpi
On Mon, 9 Jun 2025, Matthew Knepley wrote:
> It appears that MPICH 4.2.3 is incompatible with C++ clang. You can have
> PETSc download and build the latest MPICH using
>   --download-mpich
>   Thanks,
>      Matt
> On Mon, Jun 9, 2025 at 6:05 AM David Jiawei LUO LIANG <
> 12431140 at mail.sustech.edu.cn> wrote:
> > Ok, the configure.log is attached.
> > I try again configuration without cxx
> > *➜* ./configure --with-cxx=0 --with-pic --with-make-np=4
> > --with-mpi-compilers=1 --with-mpi-dir=/Users/lawkawai/lib/mpich-4.2.3-opt/
> > --with-scalar-type=real --with-precision=double --download-mumps
> > --download-scalapack --download-metis --download-hdf5 --download-slepc
> > --download-hypre --with-debugging=no
> > --prefix=/Users/lawkawai/codes/HPC_class/HW5/lib/petsc-3.22.1-opt
> >                          Configuring PETSc to compile on your system
> > TESTING: configureExternalPackagesDir from
> > config.framework(config/BuildSystem/config/framework.py:1092)
> >            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > details):
> >                 Package hypre requested requires C++ but compiler turned
> > off.
> > bu I need hypre, and it needs C++ to compile
> > Sorry, I attached the wrong configure.log.
> > This is the right configure.log for the MPI & C++ errors
> > David Jiawei LUO LIANG
> > 南方科技大学/学生/研究生/2024
> > 广东省深圳市南山区学苑大道1088号
> > ------------------ Original ------------------
> > *From: * "Matthew Knepley"<knepley at gmail.com>;
> > *Date: * Mon, Jun 9, 2025 05:44 PM
> > *To: * "Jose E. Roman"<jroman at dsic.upv.es>;
> > *Cc: * "David Jiawei LUO LIANG"<12431140 at mail.sustech.edu.cn>;
> > "petsc-dev"<petsc-dev at mcs.anl.gov>;
> > *Subject: * Re: [petsc-dev] Petsc cannot be configure
> > Yes, send the configure log.
> > It seems that you did not build the C++ bindings for MPICH. You can shut
> > of C++ in PETSc using
> >   --with-cxx=0
> >   Thanks,
> >      Matt
> > On Mon, Jun 9, 2025 at 5:42 AM Jose E. Roman via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> >> You should always attach the configure.log file.
> >> Thanks.
> >> Jose
> >> > El 9 jun 2025, a las 11:14, David Jiawei LUO LIANG <
> >> 12431140 at mail.sustech.edu.cn> escribió:
> >> > ./configure --with-x=0 -with-pic --with-make-np=4
> >> --with-mpi-compilers=1 --with-mpi-dir=/Users/lawkawai/lib/mpich-4.2.3-opt/
> >> --with-scalar-type=real --with-precision=double --with-mumps=1
> >> --download-mumps --with-scalapack=1 --download-scalapack --with-blacs=1
> >> --download-blacs --download-fblaslapack --download-metis --download-hdf5
> >> --with-debugging=no --download-slepc
> >> --prefix=/Users/lawkawai/lib/petsc-3.23.3-opt
> >> > the error:
> >> >                          Configuring PETSc to compile on your system
> >> >                                      ***** WARNING *****
> >> >   Found environment variable: FFLAGS=-w -fallow-argument-mismatch -O2.
> >> Ignoring it! Use
> >> >   "./configure FFLAGS=$FFLAGS" if you really want to use this value
> >> >   Using default C optimization flags "-g -O3". You might consider
> >> manually setting optimal
> >> >   optimization flags for your system with COPTFLAGS="optimization
> >> flags" see
> >> >   config/examples/arch-*-opt.py for examples
> >> >   Using default Cxx optimization flags "-g -O3". You might consider
> >> manually setting
> >> >   optimal optimization flags for your system with
> >> CXXOPTFLAGS="optimization flags" see
> >> >   Using default FC optimization flags "-g -O". You might consider
> >> >   optimization flags for your system with FOPTFLAGS="optimization
> >> flags" see
> >> >   You have a version of GNU make older than 4.0. It will work, but may
> >> not support all the
> >> >   parallel testing options. You can install the latest GNU make with
> >> your package manager,
> >> >   such as Brew or MacPorts, or use the --download-make option to get
> >> the latest GNU make
> >> > TESTING: CxxMPICheck from
> >> config.packages.MPI(config/BuildSystem/config/packages/MPI.py:673)
> >> >            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> >> for details):
> >> >                        C++ error! MPI_Finalize() could not be located!
> >> > Iam sure my mpich is good, it has been tested.  But the petsc configure
> >> still fail.
> >> > David Jiawei LUO LIANG南方科技大学/学生/研究生/2024广东省深圳市南山区学苑大道1088号
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > -- Norbert Wiener
> > https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ajgkAkDpjBBVmlczaLVO6Kdl1Oe_nfZxVLQC3_tHVIz3FFvUj13xyOiYSoRLmAaJMmU_JFljVPKtMtoN0TdH$
> > <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ajgkAkDpjBBVmlczaLVO6Kdl1Oe_nfZxVLQC3_tHVIz3FFvUj13xyOiYSoRLmAaJMmU_JFljVPKtMtD7BqAw$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250610/a19584fb/attachment-0001.html>
