[petsc-dev] NULL arg for AIJ field with MATIS
    Mark Adams
    mfadams at lbl.gov
    Mon Jul  7 06:21:30 CDT 2025
Mark Adams reacted via Gmail
<https://urldefense.us/v3/__https://www.google.com/gmail/about/?utm_source=gmail-in-product&utm_medium=et&utm_campaign=emojireactionemail*app__;Iw!!G_uCfscf7eWS!ZCvL2B3RCyVU8AELVaVz1mh39rVjbdj17eUx59EvTOv1mWKiKHjQyYXHkpPt1EtphrAvg1z6E5pJ7B-R37wmKA$ >
On Sun, Jul 6, 2025 at 2:13 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jul 3, 2025 at 2:25 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I added a case to the SeqAIJ options switch:
> It looks like the local matrix is created by MatSetLocalToGlobalMapping(),
> so you cannot call MatSetOption() before that. You should probably put in a
> check
>   if (a->A)
> here.
>   Thanks,
>      Matt
>>  case MAT_COO_BLOCKED_ASSEMBLY:
>>     A->coo_blocked_assembly = flg;
>>     break;
>> And added the flag for this to mat/tests/ex123* and when we have
>> '-mat_type is', I get matis calling *MatSetOption* with a NULL argument
>> (a->A)
>> What is wrong here? Not being able to use blocked assembly for matis is
>> fine, but this is not a useful error message.
>> x* thread #1, queue = 'com.apple.main-thread', stop reason = breakpoint
>> 1.1
>>     frame #0: 0x0000000128c58223 libpetsc.3.023.dylib`PetscError(comm=0,
>> line=-1, func=0x0000000000000000, file="", n=PETSC_SUCCESS,
>> p=PETSC_ERROR_INITIAL, mess="*Null Pointer: Parameter # %d*") at
>> err.c:387
>>     frame #1: 0x000000011fa3df99 libpetsc.3.023.dylib`*MatSetOption(mat=0x0000000000000000,
>> op=MAT_COO_BLOCKED_ASSEMBLY, flg=PETSC_TRUE) a*t matrix.c:6048:3
>>   * frame #2: 0x000000011ebdcfef
>> libpetsc.3.023.dylib`MatSetOption_IS(A=0x0000621000004350,
>> op=MAT_COO_BLOCKED_ASSEMBLY, flg=PETSC_TRUE) at matis.c:3286:3
>>     frame #3: 0x000000011fa4a7e0
>> libpetsc.3.023.dylib`MatSetOption(mat=0x0000621000004350,
>> op=MAT_COO_BLOCKED_ASSEMBLY, flg=PETSC_TRUE) at matrix.c:6127:3
>>     frame #4: 0x000000011fd87f66
>> libpetsc.3.023.dylib`MatSetFromOptions(B=0x0000621000004350) at
>> gcreate.c:320:12
>>     frame #5: 0x00000001000039d3 ex123`main(argc=11,
>> args=0x000000030412d1f0) at ex123.c:44:3
>>     frame #6: 0x0000000200018530 dyld`start + 3056
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZCvL2B3RCyVU8AELVaVz1mh39rVjbdj17eUx59EvTOv1mWKiKHjQyYXHkpPt1EtphrAvg1z6E5pJ7B8UJsbfyA$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZCvL2B3RCyVU8AELVaVz1mh39rVjbdj17eUx59EvTOv1mWKiKHjQyYXHkpPt1EtphrAvg1z6E5pJ7B_73jpsKA$ >
Name: not available
Type: text/vnd.google.email-reaction+json
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250707/1a310a50/attachment.bin>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250707/1a310a50/attachment.html>
