[petsc-dev] pbjacobi error, in parallel, on kokkos/cuda
    Mark Adams
    mfadams at lbl.gov
    Tue Feb 18 10:21:40 CST 2025
And, I forgot that the GAMG coarse grid (and this tiny grid) are forced to
one processor, hence valgrind errors only on one process.
Add: -pc_gamg_parallel_coarse_grid_solver -ne 13
If you want to see valgrind errors on all 4 processors.
On Tue, Feb 18, 2025 at 11:07 AM Mark Adams <mfadams at lbl.gov> wrote:
> Also, this uses the branch: adams/mat-rap-blocksize
> that has fixes to get the block sizes moved up in P'AP.
> On Tue, Feb 18, 2025 at 9:29 AM Mark Adams <mfadams at lbl.gov> wrote:
>> I've got a bug in pbjacobi that only shows up on* the Galerkin coarse
>> grid *(I have not been able to reproduce it a fine grid at least), and
>> in *parallel*, and on *GPUs*/kokkos.
>> I have modified ex55 to take P from GAMG and give it (one) to PCMG with
>> Galerkin coarse grids,and solve (code and command lines appended).
>> I see this with ex56 (bs=3 & 6), ex55 (bs=2), but ex54 (bs=1) is fine
>> (does pbjacobi switch to jacobi?)
>> With 4 processors I get these valgrind errors only on these bad solves
>> (no false positives). Note that *only one process has errors*, and note
>> some solver output before and after:
>> I'm going to keeps digging but ideas are welcome,
>> Thanks,
>> Mark
>> [0] <pc:gamg> PCSetUp_GAMG(): (null): 1) N=4, n data cols=2, nnz/row
>> (ave)=4, 1 active pes
>> [0] <pc:gamg> PCSetUp_GAMG(): (null): 2 levels, operator complexity = 1.04
>> [0] <pc:gamg> PCSetUp_GAMG(): (null): PCSetUp_GAMG: call
>> KSPChebyshevSetEigenvalues on level 0 (N=32) with emax = 2.26125 emin =
>> 0.0198344
>> [0] <pc:gamg> PCSetUp_MG(): Using outer operators to define finest grid
>> operator
>>   because PCMGGetSmoother(pc,nlevels-1,&ksp);KSPSetOperators(ksp,...);
>> was not called.
>> [0] <pc:mg> PCSetUp_MG(): Using outer operators to define finest grid
>> operator
>> was not called.
>> ==978424== Invalid read of size 16
>> ==978424==    at 0x42B9AFA2: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42AF0F12: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42C3EE7B: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42EEC474: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42B4B495: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42EC748F: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42B44781: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42CF766D: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==    by 0x42445504: ??? (in
>> /opt/nvidia/hpc_sdk/Linux_x86_64/23.9/cuda/12.2/targets/x86_64-linux/lib/libcudart.so.12.2.53)
>> ==978424==    by 0x42417A04: ??? (in
>> ==978424==    by 0x42468730: cudaMemcpy (in
>> ==978424==    by 0x4896979: cuda_memcpy_wrapper<>
>> (Kokkos_Cuda_Instance.hpp:365)
>> ==978424==    by 0x4896979: Kokkos::Impl::DeepCopyCuda(void*, void
>> const*, unsigned long) (Kokkos_CudaSpace.cpp:62)
>> ==978424==  Address 0xcb722dfc is 1,644 bytes inside a block of size
>> 1,652 alloc'd
>> ==978424==    at 0x4E0A926: memalign (in
>> /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
>> ==978424==    by 0x4E0AA69: posix_memalign (in
>> ==978424==    by 0x57E3BD9: PetscMallocAlign (mal.c:52)
>> ==978424==    by 0x57E892F: PetscTrMallocDefault (mtr.c:175)
>> ==978424==    by 0x57E5A77: PetscMallocA (mal.c:421)
>> ==978424==    by 0x63B02F5: MatInvertBlockDiagonal_SeqAIJ (aij.c:3333)
>> ==978424==    by 0x69B0599: MatInvertBlockDiagonal (matrix.c:10908)
>> ==978424==    by 0x629D585: MatInvertBlockDiagonal_MPIAIJ (mpiaij.c:2588)
>> ==978424==    by 0x7C7F726: PCSetUp_PBJacobi_Host (pbjacobi.c:256)
>> ==978424==    by 0x7D737D8: PCSetUp_PBJacobi_Kokkos
>> (pbjacobi_kok.kokkos.cxx:90)
>> ==978424==    by 0x7C803F8: PCSetUp_PBJacobi (pbjacobi.c:296)
>> ==978424==
>> ==978424==    at 0x42B9AFB4: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==  Address 0xcb722e0c is 8 bytes after a block of size 1,652
>> alloc'd
>> ==978424==
>> ==978424== Invalid read of size 4
>> ==978424==    at 0x42B9B103: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> ==978424==  Address 0xcb722e1c is 12 bytes after a block of size 1,664 in
>> arena "client"
>> ==978424==
>> ==978424==    at 0x42B9B107: ??? (in /usr/lib64/libcuda.so.550.127.08)
>> arena "client"
>> ==978424==
>>       Residual norms for rap_mg_coarse_ solve.
>>       0 KSP Residual norm 1.118121970641e+01
>>       1 KSP Residual norm 3.575439993035e-01
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Diverged due to indefinite preconditioner, beta
>> -0.00553023, betaold 5.27744
>> ksp/ex55:
>>     PC pc;
>>   PetscCall(KSPGetPC(ksp, &pc));
>>   PC_MG   *mg      = (PC_MG *)pc->data;
>>   PC_MG_Levels **mglevels = mg->levels;
>>   Mat P = mglevels[mg->nlevels-1]->interpolate;
>>   PetscCall(MatViewFromOptions(mglevels[mg->nlevels-1]->A, NULL,
>> "-rap_mat_view"));
>>   PetscCall(MatViewFromOptions(Amat, NULL, "-rap_mat_view"));
>>   KSP ksp2;
>>   PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp2));
>>   PetscCall(KSPSetOptionsPrefix(ksp2, "rap_"));
>>   PetscCall(KSPSetFromOptions(ksp2));
>>   PetscCall(KSPGetPC(ksp2, &pc));
>>   PetscCall(KSPSetOperators(ksp2, Amat, Amat));
>>   PetscCall(PCMGSetGalerkin(pc, PC_MG_GALERKIN_PMAT));
>>   PetscCall(PCMGSetInterpolation(pc, 1, P));
>>   PetscCall(VecSet(bb, 1.0));
>>   PetscCall(PetscLogStagePush(stage[1]));
>>   PetscCall(KSPSolve(ksp2, bb, xx));
>>   PetscCall(PetscLogStagePop());
>>   PetscCall(PetscFinalize());
>>   exit(12);
>>   PetscCall(PetscLogStagePush(stage[1])); // original ex55 code
>>   PetscCall(KSPSolve(ksp, bb, xx));
>> *$ srun -n 4 valgrind --tool=memcheck --leak-check=no ./ex55 -ne 3
>> -pc_type gamg -rap_pc_type mg -rap_ksp_monitor -rap_mg_levels_pc_type
>> jacobi -rap_mg_coarse_pc_type pbjacobi -rap_mg_coarse_ksp_monitor
>> -options_left -rap_pc_mg_levels 2 -rap_mg_coarse_ksp_type cg -mat_type
>> aijkokkos -fp_trap -ksp_monitor -rap_ksp_viewxx -info :pc,dm
>> -rap_mg_coarse_ksp_error_if_not_converged *
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250218/7a381fc5/attachment.html>
