[petsc-dev] Inquiry about contributing to MMG interface
    neil liu
    liufield at gmail.com
    Wed Feb  5 09:39:00 CST 2025
It seems the figures were  broken. Please see the following attached.
On Wed, Feb 5, 2025 at 10:36 AM neil liu <liufield at gmail.com> wrote:
> Hi, Mark,
> For example, in the left figure, the yellow rectangular face needs to be
> preserved during mesh refinement. However, without specifying its four
> corner points, the rectangle cannot be maintained, as shown in the right
> figure. Additionally, the four edges of this face must be recorded and
> retrieved for post-processing.
> This yellow face is an *open boundary*, meaning it is not an interface
> between different materials. To ensure its preservation during mesh
> refinement, MMG must be run in *opnbdy* (open boundary) mode.
> Thanks a lot,
> Xiaodong
> [image: image.png] [image: image.png]
> On Wed, Feb 5, 2025 at 10:05 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Feb 5, 2025 at 9:52 AM neil liu <liufield at gmail.com> wrote:
>>> Dear developers,
>>> I am currently working with MMG in the context of PETSc and have
>>> identified a need to modify the existing MMG interface,
>>> DMAdaptMetric_Mmg_Plex(), for our use case. Given these requirements, I
>>> would like to explore the feasibility of contributing to PETSc to enhance
>>> this interface, which has been verified and validated in our research code.
>>> *Proposed Modifications:*
>>>    1.
>>>    *Additional Labels for Physical Entities:*
>>>    - In addition to the existing bdLabel and rgLabel, our case requires
>>>       two additional labels to represent physical vertices and edges within the
>>>       computational domain (3D).
>>> I am open to this. Can you be more specific about what it means?
>>>    1.
>>>       - One approach is to introduce two new parameters in the
>>>       subroutine’s input list. However, this may require modifications across
>>>       related components, such as Pragmatic.
>>> This is not a problem. I can modify those.
>>>    1.
>>>    *Support for Open Boundaries:*
>>>    - The current interface does not support open boundaries, a feature
>>>       available in MMG.
>>>       - As a result, several MMG benchmark cases involving open
>>>       boundary remeshing cannot be executed within PETSc.
>>> Can you explain what this means? What is an open boundary exactly?
>>> Would this be a viable contribution to PETSc? If so, I would appreciate
>>> any guidance on the best approach to implementing these changes while
>>> maintaining compatibility with existing features.
>> Yes. Please make a fork of the petsc repo, make a branch with the
>> proposed changes, make an MR for that branch, and add me to your fork (I am
>> knepley on GitLab). I can help you get it going.
>>   Thanks,
>>     Matt
>>> Looking forward to your thoughts.
>>> Best regards,
>>> Thanks,
>>> Xiaodong
>> experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!anvbtQDqn57whvgg2qc1Dix0Izm9kxNlvUkeyYkcfknnt6VmqbCE0mlGSj6O1DLJx6qR7-7UsHv48zYw8JWNLw$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!anvbtQDqn57whvgg2qc1Dix0Izm9kxNlvUkeyYkcfknnt6VmqbCE0mlGSj6O1DLJx6qR7-7UsHv48zbaqVDECw$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250205/1e54e81f/attachment-0001.html>
Name: The right figure.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250205/1e54e81f/attachment-0002.png>
Name: The left figure.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250205/1e54e81f/attachment-0003.png>
