[petsc-dev] Problem pip installing petsc4py on existing PETSc installation
    Satish Balay
    balay.anl at fastmail.org
    Fri Aug 29 10:24:36 CDT 2025
Ah - looks like the option to use is: --no-build-isolation (if the build requirements are already installed)
Satish
balay at pj02:~/petsc$ python -m pip install --user wheel numpy setuptools cython==3.0.12
Collecting wheel
  Downloading wheel-0.45.1-py3-none-any.whl.metadata (2.3 kB)
Requirement already satisfied: numpy in /usr/lib64/python3.12/site-packages (1.26.4)
Requirement already satisfied: setuptools in /usr/lib/python3.12/site-packages (69.0.3)
Collecting cython==3.0.12
  Downloading Cython-3.0.12-cp312-cp312-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (3.3 kB)
Downloading Cython-3.0.12-cp312-cp312-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (3.5 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.5/3.5 MB 6.3 MB/s eta 0:00:00
Downloading wheel-0.45.1-py3-none-any.whl (72 kB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 72.5/72.5 kB 4.1 MB/s eta 0:00:00
Installing collected packages: wheel, cython
Successfully installed cython-3.0.12 wheel-0.45.1
balay at pj02:~/petsc$ PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-linux-c-debug python -m pip install --verbose --no-build-isolation src/binding/petsc4py
Using pip 23.3.2 from /usr/lib/python3.12/site-packages/pip (python 3.12)
Defaulting to user installation because normal site-packages is not writeable
Processing ./src/binding/petsc4py
  Running command Preparing metadata (pyproject.toml)
<snip>
  Preparing metadata (pyproject.toml) ... done
Requirement already satisfied: numpy<2 in /usr/lib64/python3.12/site-packages (from petsc4py==3.21.6) (1.26.4)
Building wheels for collected packages: petsc4py
  Running command Building wheel for petsc4py (pyproject.toml)
  running bdist_wheel
  running build
  running build_src
  using Cython 3.0.12
  cythonizing 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
<snip>
  Building wheel for petsc4py (pyproject.toml) ... done
  Created wheel for petsc4py: filename=petsc4py-3.21.6-cp312-cp312-linux_x86_64.whl size=11288013 sha256=72be29eb718c43875e423ba22dbbcd0fd33a078c042a89373ae67a6bf886abd0
  Stored in directory: /tmp/pip-ephem-wheel-cache-yhfxq7hs/wheels/ab/ca/ed/9a2ee0271ce3654f467915ae1f28d46ace120416127b0c8cf1
Successfully built petsc4py
Installing collected packages: petsc4py
Successfully installed petsc4py-3.21.6
balay at pj02:~/petsc$ python -m pip list --user
Package  Version
Cython   3.0.12
petsc4py 3.21.6
wheel    0.45.1
On Fri, 29 Aug 2025, Satish Balay wrote:
> For older release - looks like its best to download the petsc4py source tarball, modify pyproject.toml [as below] - and then install it (with the suggested 'pip' command).
> Newer petsc/petsc4py versions have fixes that work with cython-3.1
> Satish
> On Fri, 29 Aug 2025, Samar Khatiwala via petsc-dev wrote:
> > Hi Satish,
> > Thanks for taking the time to help debug this. That you ran into the same issue is reassuring in a way (that I wasn’t doing something silly). Sounds like there’s not much to be done about it but hopefully this only affects a few older versions of petsc4py.
> > It is bizarre that pip is not accepting that 3.0.12 satisfies the requirement. I thought I found a clever way to override what is in pyproject.toml by specifying “cython==3.0.12” in a constraints.txt file with the -c option. But pip ignored that too and proceeded to download cython 3.1.3.
> > As for re-downloading packages (cython, numpy) even when they’re already installed is I think by pip’s design because these are build-time requirements (and not runtime requirements).
> > Thanks,
> > Samar
> > > On Aug 29, 2025, at 1:51 AM, Satish Balay <balay.anl at fastmail.org> wrote:
> > > On Thu, 28 Aug 2025, Satish Balay wrote:
> > >> Likely:
> > >> pip install -v cython=3.0.12 petsc4py==3.21.1
> > > https://urldefense.us/v3/__https://petsc.org/release/petsc4py/install.html__;!!G_uCfscf7eWS!ccM-EknCNavnpHXV7-_uoEddj8ar6876_brlmFbYTOL8M-IaAH5Y_NIbolpNF7JlYXLunOXzURWtoLI0czE1HjrvaZuc3x0XTwfBaw$
> > > suggests:
> > > $ python -m pip install src/binding/petsc4py
> > > However:
> > > balay at pj02:~/petsc$ which cython
> > > ~/.local/bin/cython
> > > balay at pj02:~/petsc$ cython --version
> > > Cython version 3.0.12
> > > balay at pj02:~/petsc$ PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-linux-c-debug python -m pip install --verbose src/binding/petsc4py
> > >  Running command pip subprocess to install build dependencies
> > >  Collecting cython>=3
> > >    Downloading cython-3.1.3-cp312-cp312-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (4.7 kB)
> > >  Collecting numpy
> > >    Downloading numpy-2.3.2-cp312-cp312-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl.metadata (62 kB)
> > >       ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.1/62.1 kB 2.1 MB/s eta 0:00:00
> > >  Collecting setuptools
> > >    Downloading setuptools-80.9.0-py3-none-any.whl.metadata (6.6 kB)
> > >  Downloading cython-3.1.3-cp312-cp312-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl (3.3 MB)
> > >     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.3/3.3 MB 8.3 MB/s eta 0:00:00
> > >  Downloading numpy-2.3.2-cp312-cp312-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl (16.6 MB)
> > >     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 16.6/16.6 MB 8.0 MB/s eta 0:00:00
> > >  Downloading setuptools-80.9.0-py3-none-any.whl (1.2 MB)
> > >     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 8.9 MB/s eta 0:00:00
> > >  Installing collected packages: setuptools, numpy, cython
> > >  Successfully installed cython-3.1.3 numpy-2.3.2 setuptools-80.9.0
> > > I'm not sure why `3.0.12` is not satisfying the `cython>=3` requirement - and `cython-3.1.3` is installed for this requirement
> > > Ok - try to force 3.0.12:
> > > balay at pj02:~/petsc$ git diff
> > > diff --git a/src/binding/petsc4py/pyproject.toml b/src/binding/petsc4py/pyproject.toml
> > > index 6987c0389ed..35b08945f2a 100644
> > > --- a/src/binding/petsc4py/pyproject.toml
> > > +++ b/src/binding/petsc4py/pyproject.toml
> > > @@ -1,6 +1,6 @@
> > > [build-system]
> > > requires = [
> > > -  "cython >= 3",
> > > +  "cython == 3.0.12",
> > >   "numpy",
> > >   "setuptools",
> > >  Collecting numpy
> > >       ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.1/62.1 kB 1.9 MB/s eta 0:00:00
> > >     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.5/3.5 MB 41.4 MB/s eta 0:00:00
> > >     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 16.6/16.6 MB 4.9 MB/s eta 0:00:00
> > >     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 5.2 MB/s eta 0:00:00
> > >  Successfully installed cython-3.0.12 numpy-2.3.2 setuptools-80.9.0
> > >  Created wheel for petsc4py: filename=petsc4py-3.21.6-cp312-cp312-linux_x86_64.whl size=11282654 sha256=462b32dc3706d841a0fca5c7e9ba7b6127b0633cd943eef3784dc8f956375c1b
> > >  Stored in directory: /tmp/pip-ephem-wheel-cache-du9_e3hc/wheels/ab/ca/ed/9a2ee0271ce3654f467915ae1f28d46ace120416127b0c8cf1
> > > balay at pj02:~/petsc$ pip list --user
> > > Package  Version
> > > Cython   3.0.12
> > > petsc4py 3.21.6
> > > balay at pj02:~/petsc$ git branch
> > > * release-3.21
> > > Ok - now 3.0.12 is getting used (the local install is skipped again - and a new pkg is downloaded/installed as part of the build?) , and the build is now successful
> > > Satish
