[petsc-dev] Problem pip installing petsc4py on existing PETSc installation
    Samar Khatiwala
    samar.khatiwala at earth.ox.ac.uk
    Thu Aug 28 09:59:30 CDT 2025
Hi Satish,
Thanks for the reply.
I’ve done a bunch more tests and I think the issue is as you suggest the cython version (<3 and >=3 are very different).
My python installation has cython 0.29.37. However, when doing a pip install, pip insists on downloading cython>=3. The reason is that pyproject.toml and conf/confpetsc.py have this cython version as a requirement.
On the other hand, I can install petsc4py along with PETSc using --with-petsc4py=1 at configure time. If I understand things correctly, when petsc4py is installed along with PETSc, it builds the extension module using python (and not pip) so the requirements are likely ignored. In fact, if I hack pyproject.toml and confpetsc.py and set the source to the pre-packaged petsc4py in $PETSC_DIR/src/binding/petsc4py I get much further along with pip (not all the way though, but for other reasons).
From all this I’m fairly certain now that 3.21.1 is not compatible with cython>=3. Is it possible that the cython (and numpy) requirements on PyPI for older versions of PETSc/petsc4py are not correct?
Samar
On Aug 28, 2025, at 11:07 PM, Satish Balay <balay.anl at fastmail.org> wrote:
On Thu, 28 Aug 2025, Samar Khatiwala via petsc-dev wrote:
Hello,
I’m trying to install petsc4py with pip on a machine with an existing PETSc (3.21.1) (installed without pets4py). When I do:
pip install -v petsc4py==3.21.1
the installation fails. (If I don’t specify the version pip just downloads the latest version and the installation fails in a different way, but that’s not surprising.)
I’ve attached the build log.
If I don’t specify PETSC_DIR etc and just do pip install petsc4py then that works. But I would like to use the existing installed PETSc (yes, I know it is quite old but please bear with me!).
 Successfully installed cython-3.1.3 numpy-2.0.2 setuptools-80.9.0
<snip>
 using Cython 3.1.3
 cythonizing 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
 warning: petsc4py/PETSc/petscis.pxi:196:4: '__getsegcount__' relates to the old Python 2 buffer protocol and is no longer used.
 warning: petsc4py/PETSc/petscis.pxi:201:4: '__getreadbuffer__' relates to the old Python 2 buffer protocol and is no longer used.
 warning: petsc4py/PETSc/petscvec.pxi:585:4: '__getsegcount__' relates to the old Python 2 buffer protocol and is no longer used.
 warning: petsc4py/PETSc/petscvec.pxi:590:4: '__getreadbuffer__' relates to the old Python 2 buffer protocol and is no longer used.
 warning: petsc4py/PETSc/petscvec.pxi:595:4: '__getwritebuffer__' relates to the old Python 2 buffer protocol and is no longer used.
 Error compiling Cython file:
     @classmethod
     def Print(
         cls,
         *args: Any,
         sep: str = ' ',
 petsc4py/PETSc/Sys.pyx:159:19: Compiler crash in ExpressionWriter
 Compiler crash traceback from this point on:
   File "Cython/Compiler/Visitor.py", line 174, in Cython.Compiler.Visitor.TreeVisitor._visit
   File "/private/var/folders/d3/w861tc0j755f19272xfkq56w0000gn/T/pip-install-1e_zq9u1/petsc4py_c977438422fb480b9f145e0099e7cf3e/conf/cyautodoc.py", line 28, in visit_UnicodeNode
     self.emit_string(node, '')
 AttributeError: 'ExpressionWriter' object has no attribute 'emit_string'
 error: Cython failure: 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
Perhaps you can try installing/using an older cython version - say 3.0.12 - and see if that works.
Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250828/cc8e2cb7/attachment-0001.html>
