[petsc-dev] issue with v3.21.5 build
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 29 10:04:30 CDT 2025
On Tue, Apr 29, 2025 at 10:36 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
> Made it a little further. Then some new clang errors.
> clang: error: unknown argument: '-mfp16-format=ieee'
> I really appreciate the help, Matt.
We don't add that, and I think this is the wrong log file.
I see Satish has successfully built with those options.
     Matt
> Jeffrey
> On Tue, Apr 29, 2025 at 10:30 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Apr 29, 2025 at 10:27 AM Jeffrey Hyman <hymanjd at gmail.com> wrote:
>>> Oh, I remember that now. conda used to be so helpful. It always gets me
>>> when I try to rebuild.
>>> I removed it and got stuck in hdf5 again. Anaconda is gone, but it looks
>>> lille mpif90 was not found.
>>> configure:7444: mpif90 -c  -ffree-line-length-none -ffree-line-length-0
>>> -Wno-lto-type-mismatch -O3 -Wno-unused-function -fallow-argument-mismatch
>>> -fallow-argument-mismatch  conftest.f90 >&5
>>> ./configure: line 2482: mpif90: command not found
>>> should I try --download-mpich=
>>> https://urldefense.us/v3/__https://www.mpich.org/static/downloads/4.3.0/mpich-4.3.0.tar.gz__;!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl1enaIUs$ . that
>>> Satish suggested?
>> Yes, since now it seems you do not have an MPI.
>>   THanks,
>>     Matt
>>> J
>>> On Tue, Apr 29, 2025 at 10:12 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Apr 29, 2025 at 10:09 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>> wrote:
>>>>> did 1 - 4, now I'm getting an error configuring hdf5. configure.log
>>>>> attached,
>>>> I forgot to look at your environment. This is what was causing your MPI
>>>> issues. Always turn off all Anaconda stuff in the env when building PETSc.
>>>> -ffree-line-length-0 -Wno-lto-type-mismatch -O3 -Wno-unused-function
>>>> -fallow-argument-mismatch -fallow-argument-mismatch -x f95 conftest.f90 >&5
>>>> /Users/hymanjd/opt/anaconda3/bin/mpif90: line 392:
>>>> x86_64-apple-darwin13.4.0-gfortran: command not found
>>>> configure:7444: $? = 127
>>>> configure: failed program was:
>>>> |       program main
>>>> |       end
>>>> configure:7454: result: unknown
>>>> configure:7457: error: Fortran could not compile .f90 files
>>>> It has ceased to be a force for good.
>>>>   Thanks,
>>>>      Matt
>>>> On Tue, Apr 29, 2025 at 9:41 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Tue, Apr 29, 2025 at 9:28 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>> wrote:
>>>>>>> I know he and Richard have it on the to do list. But I'll encourage
>>>>>>> them at a meeting tomorrow. : )
>>>>>>> That file for the make to work, but the check failed. Looks like MPI
>>>>>>> might have gotten crossed up in all the installs?
>>>>>> Yes, I would
>>>>>> 1) Preserve the reconfigure-***.py and gmakegen.py
>>>>>> 2) Remove the whole $PETSC_DIR
>>>>>> 3) Get rid of the preinstalled OpenMPI you have. It is usually
>>>>>> somewhat broken and not helping.
>>>>>> 4) Reclone and rebuild
>>>>>>   THanks,
>>>>>>      Matt
>>>>>>> Thanks, Matt! Feels close.
>>>>>>> J
>>>>>>> On Tue, Apr 29, 2025 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Tue, Apr 29, 2025 at 9:17 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Unfortunately, Pflotran hasn't been updated to use 3.22 yet. So
>>>>>>>>> I'm stuck with 3.21.5. Can I hack the python path?
>>>>>>>> Tell Glenn to get in gear :)
>>>>>>>> I think you can just get this file:
>>>>>>>> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-__;!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl1FAfliQ$
>>>>>>>>  /blob/release-3.22/config/gmakegen.py?ref_type=heads
>>>>>>>> and put it in $PETSC_DIR/config/gmakegen.py
>>>>>>>> Finger crossed,
>>>>>>>>    Matt
>>>>>>>>> J
>>>>>>>>> On Tue, Apr 29, 2025 at 9:14 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Tue, Apr 29, 2025 at 9:08 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> This configure worked
>>>>>>>>>>> ./configure --COPTFLAGS='-O3' --CXXOPTFLAGS='-O3'
>>>>>>>>>>> --FOPTFLAGS='-O3 -Wno-unused-function -fallow-argument-mismatch'
>>>>>>>>>>> --with-debugging=no --download-mpich=yes --download-hdf5=yes
>>>>>>>>>>> --download-hdf5-fortran-bindings=yes --download-fblaslapack=yes
>>>>>>>>>>> --download-metis=yes --download-parmetis=yes  --download-cmake=
>>>>>>>>>>> https://urldefense.us/v3/__https://gitlab.kitware.com/cmake/cmake/-/archive/v3.31.7/cmake-v3.31.7.tar.gz__;!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl_ZMADHY$
>>>>>>>>>>> --download-cmake-cc=clang --download-cmake-cxx=clang++
>>>>>>>>>>> but then it failed on the make. configure and make attached.
>>>>>>>>>> We could backport a check for this. The Python is newer than the
>>>>>>>>>> release 3.21.5, so we are using something that went away. If you use 3.22
>>>>>>>>>> or higher this is fixed.
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> Thanks again for the help. Much appreciated.
>>>>>>>>>>> On Tue, Apr 29, 2025 at 8:53 AM Jeffrey Hyman <hymanjd at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> I updated brew llvm to the latest clang
>>>>>>>>>>>> Homebrew clang version 20.1.3
>>>>>>>>>>>> Target: arm64-apple-darwin24.3.0
>>>>>>>>>>>> Thread model: posix
>>>>>>>>>>>> InstalledDir: /opt/homebrew/Cellar/llvm/20.1.3/bin
>>>>>>>>>>>> Configuration file:
>>>>>>>>>>>> /opt/homebrew/etc/clang/arm64-apple-darwin24.cfg
>>>>>>>>>>>> and that seems happier with gfortran. I'm guessing that
>>>>>>>>>>>> updating my mac OS to sequoia mixed stuff up.
>>>>>>>>>>>> On Tue, Apr 29, 2025 at 8:24 AM Jeffrey Hyman <
>>>>>>>>>>>>> I had tried with clang as well, but was getting this error.
>>>>>>>>>>>>> Looks like something with the arm64. Maybe remove and reinstall gfortran?
>>>>>>>>>>>>> TESTING: checkFortranNameMangling from
>>>>>>>>>>>>> config.compilers(config/BuildSystem/config/compilers.py:78
>>>>>>>>>>>>>            UNABLE to CONFIGURE with GIVEN OPTIONS (see
>>>>>>>>>>>>> configure.log for details):
>>>>>>>>>>>>>   Unknown Fortran name mangling: Are you sure the C and
>>>>>>>>>>>>> Fortran compilers are compatible?
>>>>>>>>>>>>>   Perhaps one is 64-bit and one is 32-bit?
>>>>>>>>>>>>>   See https://urldefense.us/v3/__https://petsc.org/release/faq/*macos-gfortran__;Iw!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl-pZS6Dn$
>>>>>>>>>>>>> On Tue, Apr 29, 2025 at 7:56 AM Matthew Knepley <
>>>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>>>> On Mon, Apr 28, 2025 at 10:02 PM Satish Balay <
>>>>>>>>>>>>>> balay.anl at fastmail.org> wrote:
>>>>>>>>>>>>>>> What do you have for:
>>>>>>>>>>>>>>> clang --version
>>>>>>>>>>>>>>> Try:
>>>>>>>>>>>>>>> ./configure COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS="-O3
>>>>>>>>>>>>>>> -Wno-unused-function -fallow-argument-mismatch" \
>>>>>>>>>>>>>>> --download-hdf5=yes --with-hdf5-fortran-bindings=yes
>>>>>>>>>>>>>>> --download-fblaslapack=yes \
>>>>>>>>>>>>>>> --download-metis=yes --download-parmetis=yes \
>>>>>>>>>>>>>>> CC=gcc-14 CXX=g++-14 FC=gfortran-14 --download-make=yes \
>>>>>>>>>>>>>>> --download-cmake=
>>>>>>>>>>>>>> You could use clang. Your g++ is broken:
>>>>>>>>>>>>>> Error when bootstrapping CMake:
>>>>>>>>>>>>>> Problem while running make
>>>>>>>>>>>>>> Log of errors:
>>>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Bootstrap.cmk/cmake_bootstrap.log
>>>>>>>>>>>>>> stdout:
>>>>>>>>>>>>>> In file included from
>>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/ext/string_conversions.h:43,
>>>>>>>>>>>>>>                  from
>>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/bits/basic_string.h:4154,
>>>>>>>>>>>>>>                  from
>>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/string:54,
>>>>>>>>>>>>>>                  from
>>>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.h:9,
>>>>>>>>>>>>>>                  from
>>>>>>>>>>>>>> /Users/hymanjd/src/petsc/arch-darwin-c-debug/externalpackages/cmake-3.29.0/Source/cmTimestamp.cxx:15:
>>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:141:11:
>>>>>>>>>>>>>> error: 'at_quick_exit' has not been declared in '::'
>>>>>>>>>>>>>>   141 |   using ::at_quick_exit;
>>>>>>>>>>>>>> /opt/homebrew/Cellar/gcc/14.2.0_1/include/c++/14/cstdlib:164:11:
>>>>>>>>>>>>>> error: 'quick_exit' has not been declared in '::'
>>>>>>>>>>>>>>   164 |   using ::quick_exit;
>>>>>>>>>>>>>> make: *** [cmTimestamp.o] Error 1
>>>>>>>>>>>>>> make: *** Waiting for unfinished jobs....
>>>>>>>>>>>>>>                       Error running configure on CMAKE:
>>>>>>>>>>>>>> Could not execute "['./configure
>>>>>>>>>>>>>> --prefix=/Users/hymanjd/src/petsc/arch-darwin-c-debug --parallel=8
>>>>>>>>>>>>>> CC="/opt/homebrew/bin/gcc-14" CXX="/opt/homebrew/bin/g++-14" --
>>>>>>>>>>>>>> -DCMAKE_USE_OPENSSL=OFF']":
>>>>>>>>>>>>>> Anything that includes <string> looks like it will break.
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>> Satish
>>>>>>>>>>>>>>> On Mon, 28 Apr 2025, Jeffrey Hyman wrote:
>>>>>>>>>>>>>>> > Thanks, I'll give it a spin and let you know how it goes.
>>>>>>>>>>>>>>> > JDH
>>>>>>>>>>>>>>> > On Mon, Apr 28, 2025 at 8:43 PM Matthew Knepley <
>>>>>>>>>>>>>>> > > On Mon, Apr 28, 2025 at 8:34 PM Jeffrey Hyman <
>>>>>>>>>>>>>>> > >> Hi,
>>>>>>>>>>>>>>> > >> I am trying to build v3.21.5 to use with pflotran. I'm
>>>>>>>>>>>>>>> running into
>>>>>>>>>>>>>>> > >> issues with cmake. configure log attached.  Any
>>>>>>>>>>>>>>> suggestions?
>>>>>>>>>>>>>>> > > The documentation could be clearer here. We cannot use
>>>>>>>>>>>>>>> the PETSc compilers
>>>>>>>>>>>>>>> > > to build CMake since it explicitly does not want MPI.
>>>>>>>>>>>>>>> Thus you need to
>>>>>>>>>>>>>>> > > specify them yourself. That means you would need
>>>>>>>>>>>>>>> > >   --download-cmake-cc=/opt/homebrew/bin/gcc-14
>>>>>>>>>>>>>>> > > --download-cmake-cxx=/opt/homebrew/bin/g++-14
>>>>>>>>>>>>>>> > >   Thanks,
>>>>>>>>>>>>>>> > >      Matt
>>>>>>>>>>>>>>> > >> Thanks for the help,
>>>>>>>>>>>>>>> > >> Jeffrey
>>>>>>>>>>>>>>> > > What most experimenters take for granted before they
>>>>>>>>>>>>>>> begin their
>>>>>>>>>>>>>>> > > experiments is infinitely more interesting than any
>>>>>>>>>>>>>>> results to which their
>>>>>>>>>>>>>>> > > experiments lead.
>>>>>>>>>>>>>>> > > -- Norbert Wiener
>>>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQNOczHyI$
>>>>>>>>>>>>>>> https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQKP18rKz$
>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl85KcGm1$
>>>>>>>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl5QAD3cS$ >
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl85KcGm1$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YXoxD2_GoRH4EC8THVn5_Xa7dJ6P4ZvvoTCVRbnqPrxZYzX3nTPhETpv0W3PijYI4Sn3SG9SxhaFl5QAD3cS$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250429/fe2781a6/attachment-0001.html>
