[petsc-dev] issue with v3.21.5 build
    Jeffrey Hyman
    hymanjd at gmail.com
    Mon Apr 28 19:49:46 CDT 2025
Thanks, I'll give it a spin and let you know how it goes.
JDH
On Mon, Apr 28, 2025 at 8:43 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Apr 28, 2025 at 8:34 PM Jeffrey Hyman <hymanjd at gmail.com> wrote:
>> Hi,
>> I am trying to build v3.21.5 to use with pflotran. I'm running into
>> issues with cmake. configure log attached.  Any suggestions?
> The documentation could be clearer here. We cannot use the PETSc compilers
> to build CMake since it explicitly does not want MPI. Thus you need to
> specify them yourself. That means you would need
>   --download-cmake-cc=/opt/homebrew/bin/gcc-14
> --download-cmake-cxx=/opt/homebrew/bin/g++-14
>   Thanks,
>      Matt
>> Thanks for the help,
>> Jeffrey
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQNOczHyI$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bZa6EMKsRCbKBAnduL8Vva4vRPvbjUsz_v4OKJW8-c8D8gQcN4fZPfrAaQfZ37j1kQzigfg-TVDeQKP18rKz$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250428/fe185c86/attachment.html>
