[petsc-dev] Additive Schwarz Method + ILU on GPU platforms
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 15 12:55:05 CDT 2025
On Tue, Apr 15, 2025 at 1:45 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Hi, Justin,
>   I don't know ASM well enough. I just browsed its code. It seems it has a
> lot of matrix partitioning and indexing operations, which definitely are
> not done on GPUs currently.
>   But you could still try that, as petsc will copy data from the device to
> the host as needed to perform host-only operations.  You can profile with
> -log_vew -log_view_gpu_time so that we can see how expensive these
> operations are.
>    Barry should know more about ASM.
Usually, ASM is a tactic for solving in parallel. Each process has a
diagonal matrix block. ASM means overlapping blocks,
whereas BJacobi means non-overlapping. The block will likely be extracted
on the CPU, but pushed down to the GPU for solves.
     Matt
> --Junchao Zhang
> On Tue, Apr 15, 2025 at 10:43 AM Angus, Justin Ray <angus1 at llnl.gov>
> wrote:
>> Hi Junchao,
>> Thanks for the reply.
>> Does ASM work the same on GPU systems as it does on CPU systems?
>> *From: *Junchao Zhang <junchao.zhang at gmail.com>
>> *Date: *Monday, April 14, 2025 at 7:35 PM
>> *To: *Angus, Justin Ray <angus1 at llnl.gov>
>> *Cc: *petsc-dev at mcs.anl.gov <petsc-dev at mcs.anl.gov>, Ghosh, Debojyoti <
>> ghosh5 at llnl.gov>
>> *Subject: *Re: [petsc-dev] Additive Schwarz Method + ILU on GPU platforms
>> Petsc supports ILU0/ICC0 numeric factorization (without reordering) and
>> then triangular solve on GPUs. It is done by calling vendor libraries (ex.
>> cusparse).
>> We have options -pc_factor_mat_factor_on_host <bool>
>> -pc_factor_mat_solve_on_host <bool> to force doing the factorization and
>> MatSolve on the host for device matrix types.
>> You can try to see if it works for your case.
>> --Junchao Zhang
>> On Mon, Apr 14, 2025 at 4:39 PM Angus, Justin Ray via petsc-dev <
>> petsc-dev at mcs.anl.gov> wrote:
>> Hello,
>> A project I work on uses GMRES via PETSc. In particular, we have had good
>> successes using the Additive Schwarz Method + ILU preconditioner setup
>> using a CPU-based code. I found online where it is stated that “Parts of
>> most preconditioners run directly on the GPU” (
>> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fQqW7mjnh1VSngks4WuKIejODD259NIRzuXN8kFwXrunsgj2S6ecC6AfmnT8mUT5wQFY3F5kWSLiAlPIa5E7$
>> <https://urldefense.us/v3/__https:/petsc.org/release/faq/__;!!G_uCfscf7eWS!bw6qeKcY7MKSvlEgcogdKR7fpjZSOFvka6zfDprUZ_sJHdE-YZmRD6UTqWQW3_uGVBII4P-AG0zaGTLbI67_fQ$>).
>> Is ASM + ILU also available for GPU platforms?
>> -Justin
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fQqW7mjnh1VSngks4WuKIejODD259NIRzuXN8kFwXrunsgj2S6ecC6AfmnT8mUT5wQFY3F5kWSLiAlTztbRP$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fQqW7mjnh1VSngks4WuKIejODD259NIRzuXN8kFwXrunsgj2S6ecC6AfmnT8mUT5wQFY3F5kWSLiAoDn6W5U$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250415/84607bdb/attachment-0001.html>
