[petsc-dev] Additive Schwarz Method + ILU on GPU platforms
    Angus, Justin Ray
    angus1 at llnl.gov
    Mon Apr 14 16:39:38 CDT 2025
Hello,
A project I work on uses GMRES via PETSc. In particular, we have had good successes using the Additive Schwarz Method + ILU preconditioner setup using a CPU-based code. I found online where it is stated that “Parts of most preconditioners run directly on the GPU” (https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bw6qeKcY7MKSvlEgcogdKR7fpjZSOFvka6zfDprUZ_sJHdE-YZmRD6UTqWQW3_uGVBII4P-AG0zaGTLbI67_fQ$ ). Is ASM + ILU also available for GPU platforms?
-Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20250414/f90254bf/attachment.html>
