[petsc-dev] petsc compatibility issues with slepc
    Satish Balay
    balay.anl at fastmail.org
    Mon Nov 11 08:56:47 CST 2024
On Mon, 11 Nov 2024, David Jiawei LUO LIANG wrote:
> for petsc installed by homebrew, the dependency of open-mpi is of version 5.0.5.
> But if I configure slepc with petsc, the mpicc compiler link open-mpi of version 5.0.2, defaultly
I don't understand what issue you are having.
If you are using petsc from homebew - perhaps you should also use slepc from homebrew.
Or install both PETSc,SLEPc, openmpi from sources
[from PETSc]
./configure --download-openmpi --download-slepc
If you still have issues - please explain in more detail - and send relavent logs [for build issues - configure.log, make.log etc..]
Satish
