[petsc-dev] fortran compilation error
    Ravindra Chopade
    ravichopade73 at gmail.com
    Sat May  4 10:11:05 CDT 2024
Thank you Jose, *"make deletefortranstubs" followed by "make
allfortranstubs" *solved the issue.
Thanks
Ravi
On Sat, May 4, 2024 at 12:11 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
> There have been changes in the fortran stubs recently. Try regenerating
> the fortran stubs with "make deletefortranstubs" followed by "make
> allfortranstubs". If this does not work, try removing the $PETSC_ARCH
> directory and configure/make again.
> Jose
> > El 4 may 2024, a las 8:17, Ravindra Chopade <ravichopade73 at gmail.com>
> escribió:
> > This Message Is From an External Sender
> > This message came from outside your organization.
> > Hi All,
> > Fortran compilation started failing with below error after resolving
> conflicts for my changes Merge Request 7513, even though my changes does
> not contain any fortran changes
> > <image.png>
> > I am not a fortran guy, can someone help to understand and fix this
> issue ?
> > Thanks
> > Ravi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240504/48b95999/attachment.html>
