[petsc-dev] PetscObjectIsNull()
Barry Smith
bsmith at petsc.dev
Wed Jul 31 10:14:53 CDT 2024
I've tried to clarify the PETSc release process in https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7733__;!!G_uCfscf7eWS!eodFVPnrVRpGHgm9xR-QahUEnegpivXK-k6z2lRzuZwXV-3C10KT5rf6ec_fWF8b2lpiu3HU0ZlWqY7AfYL17A$ I hope that helps.
Barry
> On Jul 31, 2024, at 11:10 AM, Satish Balay <balay.anl at fastmail.org> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> On Wed, 31 Jul 2024, Adrian Croucher wrote:
> > On 31/07/24 4:47 pm, Satish Balay wrote:
> > > Major releases [i.e. 3.21.0, 3.22.0 etc.] are spun from main branch once
> > > every 6 months.
> > > And bug fix updates [i.e. 3.21.1, 3.21.2 etc.] are spun from release branch
> > > once every month [during this 6 month cycle].
> > > i.e PetscObjectIsNull() change that's currently in main branch won't be in a
> > > tarball (or a tagged version) until 3.22.0 release in Sept end.
> > I guess I'm still a bit confused by your system. What exactly is e.g. the
> > recent commit with tag "3.21.4", if it isn't a "tagged version"?
> > That tag appears to be on the "release" branch as well as "main" - i.e. I can
> > see it if I look at the commits for the "release" branch. So it looked to me
> > like a minor release. How are users supposed to interpret those tags?
> Sorry for all the confusion.
> You should interpret the release process as I described above. Different projects use different git workflows.
> Our release workflow:
> - New features [and other changes] go into 'main' development branch. There could be API changes here. They get released every 6 months as 3.21[.0], 3.22[.0], 3.23[.0] major releases.
> - Since this is a major release - the release branch is synced with all these changes from main (that correspond to this major release) - at this point in time.
> - Subsequent bug fixes go into this 'release' branch. There is no API changes here, These patch updates get released every month [i.e 3.21.1, 3.21.2, ... 3.21.6] until the next major release 3.22.0.
> Here one could easily update from 3.21.1 to 3.21.6 (i.e not be stuck at 3.21.0) without fear of API changes breaking their application code [and getting the bug fixes for the current release]
> - And all release bug fixes are also needed in 'main' branch - so there is a frequent merge of 'release' to main' during these 6 months.
> i.e "looking at latest tags in the main branch and assuming it corresponds to the *latest* snapshot of main changes" is min-interpreting our release workflow.
> Also note: our release docs are at: https://urldefense.us/v3/__https://petsc.org/release/__;!!G_uCfscf7eWS!cki0uYPhZTPbxunajvNTcZaxLD9JegmvdpZpXbKlwChtoCpykn6IvPXbZwK4TiVyAVJrMDktrLraRTLPqEzgUeMbxg$
> And development docs are at https://urldefense.us/v3/__https://petsc.org/main/__;!!G_uCfscf7eWS!cki0uYPhZTPbxunajvNTcZaxLD9JegmvdpZpXbKlwChtoCpykn6IvPXbZwK4TiVyAVJrMDktrLraRTLPqEzqge3b1A$ esp: https://urldefense.us/v3/__https://petsc.org/main/changes/dev/__;!!G_uCfscf7eWS!cki0uYPhZTPbxunajvNTcZaxLD9JegmvdpZpXbKlwChtoCpykn6IvPXbZwK4TiVyAVJrMDktrLraRTLPqEwbYDZzrQ$ that list the changes scheduled for the next (major) release.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240731/95acdd12/attachment-0001.html>
