[petsc-dev] PetscObjectIsNull()
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Tue Jul 30 21:00:43 CDT 2024
On 31/07/24 1:47 pm, Adrian Croucher wrote:
> I just checked the file include/petsc/finclude/petscsys.h, and it
> contained PetscObjectIsNull() until yesterday, but then it disappeared.
It is back in there again in commit 96fb8409 immediately after the
3.21.4 tag. But if you check out 3.21.4 (0d6defa7) it is missing.
I don't suppose the tag could be moved? Otherwise it looks to me like
this release is a bit broken - not useable for me anyway.
- Adrian
> - Adrian
> On 31/07/24 1:27 pm, Adrian Croucher wrote:
>> On 31/07/24 1:25 pm, Barry Smith wrote:
>>>    You need to have
>>> #include <petsc/finclude/petscsys.h>
>>>  in the file above the usage.  That is where it is defined.
>> I have:
>> #include <petsc/finclude/petsc.h>
>> Should that not still work?
>> - Adrian
>>>   Barry
>>>> On Jul 30, 2024, at 8:03 PM, Adrian Croucher
>>>> <a.croucher at auckland.ac.nz> wrote:
>>>> This Message Is From an External Sender
>>>> This message came from outside your organization.
>>>> hi
>>>> I just checked out and built the latest PETSc release 3.21.4.
>>>> When I build my code against it, it complains that the
>>>> recently-introduced PetscObjectIsNull() doesn't seem to exist any more.
>>>> e.g.:
>>>> 3677 |     if (.not. PetscObjectIsNull(sf)) then
>>>>         |             1
>>>> Error: Function ‘petscobjectisnull’ at (1) has no IMPLICIT type
>>>> Was this removed again? It still worked when I built against the main
>>>> branch up until last week.
>>>> I deleted the build dirs for both PETSc and my code and did completely
>>>> clean builds of both, but got the same error.
>>>> - Adrian
>>>> Dr Adrian Croucher
>>>> Senior Research Fellow
>>>> Department of Engineering Science
>>>> Waipapa Taumata Rau / University of Auckland, New Zealand
>>>> email:a.croucher at auckland.ac.nz
>>>> tel: +64 (0)9 923 4611
>> Dr Adrian Croucher
> Dr Adrian Croucher
Dr Adrian Croucher
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20240731/191376ef/attachment-0001.html>
