[petsc-dev] DMPlex redistribution
Adrian Croucher a.croucher at auckland.ac.nz
Thu Nov 30 16:31:04 CST 2023
hi Matt,
I last tested this with PETSc v3.19 and that was still broken, so unless
there was any progress on it in 3.20 I suspect that's still the case.
So for our code we are still basically stuck with using PETSc 3.15 at
the moment. Would be nice to be able to get that up to date again.
Cheers, Adrian
On 1/12/23 9:00 am, Matthew Knepley wrote:
> On Tue, Mar 28, 2023 at 6:12 PM Adrian Croucher
> <a.croucher at auckland.ac.nz> wrote:
>     > Yes, I think so. The partitioning groups cells, and does not
>     expect cells
>     > in the overlap. We could generalize that, which is probably
>     > the right thing to do when redistributing meshes with overlap. I
>     will look
>     > at why it is complaining. Maybe I can just put a guard instead
>     > of an error in there.
>     Yes, and it might be useful to be able to disable that check for
>     cells
>     in the overlap, for cases like this.
> Okay, I lost this in my Inbox. Is redistribution of overlapping meshes
> still broken? If so, we should make a test so that I can fix it.
>   Thanks!
>     Matt
>     - Adrian
>     Dr Adrian Croucher
>     Senior Research Fellow
>     Department of Engineering Science
>     University of Auckland, New Zealand
>     email: a.croucher at auckland.ac.nz
>     tel: +64 (0)9 923 4611
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Dr Adrian Croucher
email:a.croucher at auckland.ac.nz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20231201/5f2015c6/attachment.html>
