[petsc-dev] DMPlex redistribution
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Mon Mar 27 17:57:48 CDT 2023
hi Matt,
On 28/03/23 00:14, Matthew Knepley wrote:
> Yes, it is a new check. I do not expect cells that are shared until we
> create an overlap. We
> can just put in a flag to shut it off, since otherwise it is a great
> check for finding bugs. Can
> you show me how you add cells, so we can make a small example that
> tests this to go in
> PETSc?
Essentially I'm adding (one or more) cells nested "inside" some of the
original DM cells to simulate dual porosity. As well as new cells I also
create a new face between the original cell and the new one, and a new
edge and point for the face (so the DAG is the same depth everywhere -
otherwise it causes trouble).
In the code, I create a new DMPlex, figure out the chart including the
new cells etc., set the cone sizes and the cones. I symmetrize it, copy
labels over from the original DM, set cell types (using
DM_POLYTOPE_INTERIOR_GHOST for the new points) and set up the point SF
for the new DM. If something is wrong with that point SF, would it cause
the error I'm seeing when I redistribute?
The code for setting up the new point SF is here (hope this link works):
https://github.com/waiwera/waiwera/blob/55d26483b3392b70985fb25f998fbda3297c6154/src/mesh.F90#L3408
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email:a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230328/7c67a7dc/attachment.html>
