[petsc-dev] PetscOptionsGetViewer() problems with multiple usage on the same object but different options databases
Sun Jan 22 12:10:04 CST 2023
On Sun, Jan 22, 2023 at 1:06 PM Barry Smith <bsmith at petsc.dev> wrote:
>   That makes incrementally adding new options to an existing object
> difficult, since each call to setFromOptions() screws up previous calls.
> We already have
> -ksp_monitor_cancel
> -ksp_converged_reason_view_cancel
Let me address it another way. If I understand correctly, what happens
currently is that at each ViewFromOptions() call, the database is inspected
and if a *_view is found, then the view is executed. So when you replace
the database, if this option is not found then nothing happens. This seems
to satisfy a kind of options locality. If instead we make some options
sticky, like -ksp_view, so that once given they never expire, this would
make the code exceedingly hard to reason about, especially if options are
set deep inside something, before a user is knowingly doing things. This
does not sound like the right model to me.
   Matt
> On Jan 22, 2023, at 12:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jan 21, 2023 at 4:34 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   If I run KSPSetFromOptions() on an options database that contains
>> -ksp_view and then push another options database that does not contain
>> -ksp_view and call KSPSetFromOptions() again it undoes the previous setting
>> of that viewer.  So -ksp_view is not used.
>>   I think this is the wrong model, it should not turn off the previously
>> set view just because it is not being set in the new call, since it was
>> previously set in the KSP. I fear some PETSc function will need another
>> argument to properly handle this; like another flag to
>> PetscOptionsGetViewer().
>>   Note this is for much more than KSP.
>>  Thoughts?
> I think it must get rid of it. Otherwise, it would stay forever since
> there would be no way to get rid of it.
>   Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230122/793cd552/attachment.html>
