[petsc-dev] PetscOptionsGetViewer() problems with multiple usage on the same object but different options databases
    Matthew Knepley
    knepley at gmail.com
    Sun Jan 22 11:45:24 CST 2023
On Sat, Jan 21, 2023 at 4:34 PM Barry Smith <bsmith at petsc.dev> wrote:
>   If I run KSPSetFromOptions() on an options database that contains
> -ksp_view and then push another options database that does not contain
> -ksp_view and call KSPSetFromOptions() again it undoes the previous setting
> of that viewer.  So -ksp_view is not used.
>   I think this is the wrong model, it should not turn off the previously
> set view just because it is not being set in the new call, since it was
> previously set in the KSP. I fear some PETSc function will need another
> argument to properly handle this; like another flag to
> PetscOptionsGetViewer().
>   Note this is for much more than KSP.
>  Thoughts?
I think it must get rid of it. Otherwise, it would stay forever since there
would be no way to get rid of it.
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230122/2124c422/attachment.html>
