[petsc-dev] gcov tests on my machine before CI
Barry Smith
bsmith at petsc.dev
Thu Feb 23 11:59:26 CST 2023
Jacob,
When I am adding code it makes sense that the new code I just added is tested, at least to some degree, on my machine before I create an MR. This means that my running appropriate gcov on just my local machine should provide enough information to indicate that my new code is NOT covered (without needing a full run on the entire CI).
Can one do this trivially now? Can the code in the CI that tracks the coverage be modified in some small way to allow me to trivially do the checking myself?
For example, some gcov flag for configure and then a gcov flag for make alltests and then alltests automatically tells me all new code in my current branch that is not tested?
Thanks
Barry
