[petsc-dev] Symbol names using clang in addition to gcc
    Satish Balay
    balay at mcs.anl.gov
    Thu Sep 22 12:12:34 CDT 2022
Actually the failure on Cray is with clang.
So I'm not sure the best way to fix this is.
Satish
[balay at login2.crusher petsc]$ CC --version
Cray clang version 14.0.0  (c98838affc7b58fed2a72f164d77c35e1bc8772f)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/cray/pe/cce/14.0.0/cce-clang/x86_64/share/../bin
[balay at login2.crusher petsc]$ git diff src/sys/dll/dlimpl.c |cat
diff --git a/src/sys/dll/dlimpl.c b/src/sys/dll/dlimpl.c
index fc488603167..c73edb99f90 100644
--- a/src/sys/dll/dlimpl.c
+++ b/src/sys/dll/dlimpl.c
@@ -327,7 +327,7 @@ PetscErrorCode PetscDLAddr(void (*func)(void), char **name)
   PetscFunctionBegin;
   PetscValidPointer(name, 2);
   *name = NULL;
-#if defined(PETSC_HAVE_DLADDR) && defined(__USE_GNU)
+#if defined(PETSC_HAVE_DLADDR) && (defined(__USE_GNU) || defined(__clang__))
   dlerror(); /* clear any previous error */
     Dl_info info;
[balay at login2.crusher petsc]$ make libs
          CC arch-olcf-crusher/obj/sys/dll/dlimpl.o
/autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:333:5: error: use of undeclared identifier 'Dl_info'
    Dl_info info;
/autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:335:16: warning: implicit declaration of function 'dladdr' is invalid in C99 [-Wimplicit-function-declaration]
    PetscCheck(dladdr(*(void **)&func, &info), PETSC_COMM_SELF, PETSC_ERR_LIB, "Failed to lookup symbol: %s", dlerror());
/autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:335:41: error: use of undeclared identifier 'info'
/autofs/nccs-svm1_home1/balay/petsc/src/sys/dll/dlimpl.c:337:35: error: use of undeclared identifier 'info'
    PetscCall(PetscDemangleSymbol(info.dli_sname, name));
1 warning and 3 errors generated.
make: *** [gmakefile:195: arch-olcf-crusher/obj/sys/dll/dlimpl.o] Error 1
On Thu, 22 Sep 2022, Satish Balay via petsc-dev wrote:
> I see this is change was done at https://gitlab.com/petsc/petsc/-/merge_requests/5268
> Likely due to errors with cray compilers.
> So  I guess we could add in __clang__ as you suggest. Can you create an MR with this change?
> And probably the same fix for src/sys/objects/pinit.c ?
> Satish
> On Thu, 22 Sep 2022, Aagaard, Brad T via petsc-dev wrote:
> > Satish,
> > I used to be able to get symbol names using clang (macOS) and this still works, but I need to edit the defines in dlimpl.c because __USE_GNU is not defined. Is there a reason why the current code is limited to __USE_GNU and doesn’t allow broader use when it works?
> > Here is the change I made to my local version to allow symbol names.
> > index 5bd68aa5a33..ded4ce5adbb 100644
> > @@ -323,7 +323,7 @@ PetscErrorCode PetscDLAddr(void (*func)(void), char **name) {
> >    PetscFunctionBegin;
> >    *name = NULL;
> >      Dl_info info;
> > Thanks,
> > Brad
