[petsc-dev] Symbol names using clang in addition to gcc
Aagaard, Brad T
baagaard at usgs.gov
Thu Sep 22 11:23:05 CDT 2022
Satish,
I used to be able to get symbol names using clang (macOS) and this still works, but I need to edit the defines in dlimpl.c because __USE_GNU is not defined. Is there a reason why the current code is limited to __USE_GNU and doesn’t allow broader use when it works?
Here is the change I made to my local version to allow symbol names.
diff --git a/src/sys/dll/dlimpl.c b/src/sys/dll/dlimpl.c
index 5bd68aa5a33..ded4ce5adbb 100644
--- a/src/sys/dll/dlimpl.c
+++ b/src/sys/dll/dlimpl.c
@@ -323,7 +323,7 @@ PetscErrorCode PetscDLAddr(void (*func)(void), char **name) {
PetscFunctionBegin;
PetscValidPointer(name, 2);
*name = NULL;
-#if defined(PETSC_HAVE_DLADDR) && defined(__USE_GNU)
+#if defined(PETSC_HAVE_DLADDR) && (defined(__USE_GNU) || defined(__clang__))
dlerror(); /* clear any previous error */
Dl_info info;
Brad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220922/cd676577/attachment.html>
