[petsc-dev] large cost of symmetrizing for GAMG?
    Mark Adams
    mfadams at lbl.gov
    Sat Sep 17 08:07:27 CDT 2022
Symetrix graph make a transpose and then adds them.
I imagine adding two different matrices is expensive.
On Fri, Sep 16, 2022 at 8:30 PM Barry Smith <bsmith at petsc.dev> wrote:
> Mark,
>    I have runs of GAMG on one and two ranks with -pc_gamg_symmetrize_graph
> because the matrix is far from symmetric and some of GAMG is taking a huge
> amount more time with 2 ranks than one. (While other stuff like VecNorm
> shows improvement with two ranks). I've attached the two files
>   Have you seen this before, is there anything that can be done about? If
> going to two ranks causes almost a doubling in GAMG setup time that makes
> using parallelism not useful,
>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220917/aee77fa1/attachment.html>
