[petsc-dev] PETSc 3.18.1 undefined reference
Antonio T. sagitter sagitter at fedoraproject.org
Sat Oct 29 12:52:14 CDT 2022
Hi all.
In PETSc 3.18.1 on Fedora 36, configure is failing for undefined
reference to CGNS libraries:
Possible ERROR while running linker: exit code 1
stderr:
/usr/bin/ld: /tmp/ccvhtRGQ.ltrans0.ltrans.o: in function `main':
/tmp/petsc-o02hjls3/config.libraries/conftest.c:5: undefined reference
to `cgp_close'
collect2: error: ld returned 1 exit status
Linker output before filtering:
to `cgp_close'
Linker output after filtering:
to `cgp_close'
collect2: error: ld returned 1 exit status:
**** Configure header /tmp/petsc-o02hjls3/confdefs.h ****
We are using CGNS-4.2.0
Regards.
Antonio Trande
Fedora Project
mailto: sagitter at fedoraproject.org
GPG key server: https://keyserver1.pgp.com/
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20221029/0ad26453/attachment-0001.zip>
