[petsc-dev] petsc4py, numpy's BLAS and PETSc's BLAS
Satish Balay
balay at mcs.anl.gov
Mon Oct 24 11:42:26 CDT 2022
Hm - I see numpy on older OS - but not on M1. So Apple no longer bundles it?
And pip creates grief on NFS :(
Satish
balay at ypro ~ % sw_vers
ProductName: Mac OS X
ProductVersion: 10.15.7
BuildVersion: 19H2026
balay at ypro ~ % python3 -c "import numpy; print(numpy.__file__)"
/Users/balay/Library/Python/3.8/lib/python/site-packages/numpy/__init__.py
balay at ypro ~ %
compute-macos-240-02:~ balay$ sw_vers
ProductName: macOS
ProductVersion: 12.3.1
BuildVersion: 21E258
compute-macos-240-02:~ balay$ python3 -c "import numpy; print(numpy.__file__)"
Traceback (most recent call last):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'numpy'
On Mon, 24 Oct 2022, Zhang, Hong via petsc-dev wrote:
> The chances of these problems are very slim because almost nobody builds Numpy from source. I usually install it with pip. Pip-installed Numpy on Mac uses Openblas, which is shipped together with the numpy wheels. The official API to check which BLAS is used by Numpy is numpy.show_config(). However, it gives me false info on my laptop — the openblas libs do not really exist in /usr.local/lib.
> openblas64__info:
> libraries = ['openblas64_', 'openblas64_']
> library_dirs = ['/usr/local/lib']
> language = c
> define_macros = [('HAVE_CBLAS', None), ('BLAS_SYMBOL_SUFFIX', '64_'), ('HAVE_BLAS_ILP64', None)]
> runtime_library_dirs = ['/usr/local/lib']
> blas_ilp64_opt_info:
> language = c
> openblas64__lapack_info:
> language = c
> define_macros = [('HAVE_CBLAS', None), ('BLAS_SYMBOL_SUFFIX', '64_'), ('HAVE_BLAS_ILP64', None), ('HAVE_LAPACKE', None)]
> lapack_ilp64_opt_info:
> language = c
> Supported SIMD extensions in this NumPy install:
> baseline = SSE,SSE2,SSE3
> found = SSSE3,SSE41,POPCNT,SSE42,AVX,F16C,FMA3,AVX2
> not found = AVX512F,AVX512CD,AVX512_KNL,AVX512_SKX,AVX512_CLX,AVX512_CNL,AVX512_ICL
> I think Numpy is actually using the following openblas lib:
> /usr/local/lib/python3.10/site-packages/numpy//.dylibs/libopenblas64_.0.dylib
> I feel that it would be a big hassle if we want to determine the BLAS that Numpy is using, considering the different ways and platforms Numpy may be installed.
> Hong (Mr.)
> On Oct 21, 2022, at 4:20 PM, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
> When PETSc is built with petsc4py this brings along, in some way, the BLAS/LAPACK that numpy is using. Yet PETSc is free to bring in its own BLAS/LAPACK libraries.
> To be completely proper should we be having configure (when used with petsc4py) determine the BLAS/LAPACK that numpy is using and only using that for PETSc's BLAS/LAPACK needs? If not, why is ok to have both sets hanging around? Jose's new https://gitlab.com/petsc/petsc/-/merge_requests/5737 seems to indicate possible problems with having both.
> Barry
