[petsc-dev] DMPlexComputeGeometryFEM
Yann Jobic
yann.jobic at univ-amu.fr
Fri Nov 25 07:13:57 CST 2022
Hi all,
I made a very simple example which uses the DMPlexComputeGeometryFEM
function.
However, i've got an error :
./testComputeGeomFEM -heat_petscspace_degree 0
Quadrature of order 1 on 1 points (dim 2)
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Pointer: Parameter # 7
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
[0]PETSC ERROR:
/home/jobic/projet/fe-utils/petsc/fetools/cmake-build-debug/testComputeGeomFEM
on a named luke by jobic Fri Nov 25 14:08:34 2022
[0]PETSC ERROR: Configure options
--prefix=/local/lib/petsc/3.18/p0/gcc/nompi --with-mpi=0
--with-debugging=1 --with-blacs=1 --download-zlib,--download-p4est
--download-triangle=1 --with-single-library=0 --with-large-file-io=1
--with-shared-libraries=0 -CFLAGS=" -g -O0" -CXXFLAGS=" -g -O0"
-FFLAGS=" -g -O0" PETSC_ARCH=nompi_gcc
[0]PETSC ERROR: #1 DMPlexComputeCellGeometryFEM() at
/home/devel/src_linux/petsc-3.18.0/src/dm/impls/plex/plexgeometry.c:2158
[0]PETSC ERROR: #2 DMPlexComputeGeometryFEM() at
/home/devel/src_linux/petsc-3.18.0/src/dm/impls/plex/plexgeometry.c:2524
[0]PETSC ERROR: #3 main() at
/home/jobic/projet/fe-utils/petsc/fetools/src/testComputeGeomFEM.c:31
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -heat_petscspace_degree 0
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
Do you know where it comes from ?
Yann
static char help[] = "Test the function \n\n";
#include <petscdmplex.h>
#include <petscds.h>
#include <petscfe.h>
extern double get_volume_DM_v2(DM dm, Vec cellgeom);
int main(int argc, char **argv) {
DM dm;
Vec cellgeom; /* solution, residual vectors */
PetscFE fe;
PetscReal vol;
PetscInt dim=2,NumComp=1;
PetscInt cells[3]={2,2,2};
PetscBool isSimplice=PETSC_TRUE;
PetscQuadrature quad;
PetscCall(PetscInitialize(&argc,&argv,(char *)0,help));
PetscCall(DMPlexCreateBoxMesh(PETSC_COMM_WORLD, dim, isSimplice, cells, NULL, NULL, NULL, PETSC_TRUE, &dm));
PetscCall(PetscFECreateDefault(PetscObjectComm((PetscObject) dm), dim,NumComp,PETSC_FALSE,"heat_",PETSC_DECIDE,&fe));
PetscCall(PetscFEViewFromOptions(fe,NULL,"-fe_field_view"));
PetscCall(DMSetField(dm, 0, NULL, (PetscObject) fe));
PetscFEGetQuadrature(fe,&quad);
PetscQuadratureView(quad,PETSC_VIEWER_STDOUT_WORLD);
PetscCall(PetscFEDestroy(&fe));
PetscCall(DMCreateDS(dm));
PetscCall(DMPlexComputeGeometryFEM(dm, &cellgeom));
vol = get_volume_DM_v2(dm,cellgeom);
PetscPrintf(PETSC_COMM_WORLD, "Volume %f\n",vol);
PetscCall(VecDestroy(&cellgeom));
PetscCall(DMDestroy(&dm));
PetscCall(PetscFinalize());
return 0;
double get_volume_DM_v2(DM dm, Vec cellgeom) {
PetscDS prob;
PetscFE fe;
const PetscReal *quadWeights;
PetscInt c,q,qNc,Nq,cellHeight=0,cStart,cEnd;
PetscReal vol=0.,volG=0.;
PetscScalar *cgeom;
PetscErrorCode ierr;
DMGetDS(dm,&prob);
PetscDSGetDiscretization(prob,0,(PetscObject*) &fe);
PetscQuadratureGetData(quad, NULL, &qNc, &Nq, NULL, &quadWeights);
DMPlexGetSimplexOrBoxCells(dm, cellHeight, &cStart, &cEnd);
VecGetArray(cellgeom, &cgeom);
for (c = cStart; c < cEnd; ++c) {
PetscFEGeom *cg;
DMPlexPointLocalRef(dm, c, cgeom, &cg);
for (q = 0; q < Nq; ++q) {
if (cg->detJ < 0) {
ierr = PetscPrintf(PETSC_COMM_WORLD, "ATTENTION, volume non correct !!\n\n");
ierr = PetscFinalize();
return -1;
vol += *cg->detJ*quadWeights[q*qNc];
ierr = MPI_Allreduce(&vol, &volG, 1,MPIU_REAL, MPI_SUM,PETSC_COMM_WORLD );CHKERRQ(ierr);
return volG;
