[petsc-dev] kokkos hang after rebase over main, maybe, Crusher
Mark Adams mfadams at lbl.gov
Tue May 24 21:13:21 CDT 2022
I was working on Crusher yesterday and I think I rebased over main and now
I am hanging here.
Any ideas?
(gdb) bt
#0  0x00007fff81bd5547 in sched_yield () from /lib64/libc.so.6
#1  0x00007fff79e43665 in ?? () from
/opt/rocm-5.1.0/hsa/lib/libhsa-runtime64.so.1
#2  0x00007fff79e382f4 in ?? () from
#3  0x00007fff79e46bff in ?? () from
#4  0x00007fff79e7cd07 in ?? () from
#5  0x00007fff79e8183d in ?? () from
#6  0x00007fff79e822a3 in ?? () from
#7  0x00007fff79e553a4 in ?? () from
#8  0x00007fff8a837f0b in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#9  0x00007fff8a7f6843 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#10 0x00007fff8a7f68af in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#11 0x00007fff8a8205c4 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#12 0x00007fff8a7f5180 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#13 0x00007fff8a82e261 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#14 0x00007fff8a872100 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#15 0x00007fff8a843efd in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#16 0x00007fff8a82a253 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#17 0x00007fff8a818890 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#18 0x00007fff8a7a09f1 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#19 0x00007fff8a7a0d00 in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#20 0x00007fff8a676f4e in ?? () from /opt/rocm-5.1.0/lib/libamdhip64.so.5
#21 0x00007fff8a726575 in hipMemcpy () from
#22 0x00007fffec390194 in
Petsc::Device::CUPM::Impl::Interface<(Petsc::Device::CUPM::DeviceType)1>::PetscAliasFunctionDispatch_460_hipMemcpy<int*&,
int const (&) [2], unsigned long const&, hipMemcpyKind const&>
(args=<optimized out>, args=<optimized out>, args=<optimized out>,
args=<optimized out>)
    at include/petsc/private/cupminterface.hpp:460
#23
Petsc::Device::CUPM::Impl::Interface<(Petsc::Device::CUPM::DeviceType)1>::cupmMemcpy<int*&,
args=<optimized out>) at include/petsc/private/cupminterface.hpp:460
#24
Petsc::Device::CUPM::Device<(Petsc::Device::CUPM::DeviceType)1>::DeviceInternal::CUPMAwareMPI_
() at src/sys/objects/device/impls/cupm/cupmdevice.cxx:184
#25 0x00007fffec38ee3d in
Petsc::Device::CUPM::Device<(Petsc::Device::CUPM::DeviceType)1>::DeviceInternal::initialize
(this=<optimized out>) at
src/sys/objects/device/impls/cupm/cupmdevice.cxx:85
#26 0x00007fffec38fea0 in
Petsc::Device::CUPM::Device<(Petsc::Device::CUPM::DeviceType)1>::getDevice
(this=0x7fffed56b928 <HIPDevice>, device=0xe76f10, id=<optimized out>) at
src/sys/objects/device/impls/cupm/cupmdevice.cxx:410
#27 0x00007fffec38cfa1 in PetscDeviceCreate (type=PETSC_DEVICE_HIP,
devid=-1, device=device at entry=0x7fffed58b230 <defaultDevices+16>) at
src/sys/objects/device/interface/device.cxx:130
#28 0x00007fffec38d382 in PetscDeviceInitializeDefaultDevice_Internal
(type=14723904, defaultDeviceId=0, defaultDeviceId at entry=-1) at
src/sys/objects/device/interface/device.cxx:313
#29 0x00007fffec38e157 in PetscDeviceInitialize (type=PETSC_DEVICE_HIP) at
src/sys/objects/device/interface/device.cxx:274
#30 PetscDeviceGetDefaultForType_Internal (type=PETSC_DEVICE_HIP,
device=0x7fffffff49c0) at src/sys/objects/device/interface/device.cxx:493
#31 0x00007fffec38aad7 in
PetscDeviceContextSetDefaultDeviceForType_Internal (dctx=0xe58da0,
type=14723904) at include/petsc/private/deviceimpl.h:241
#32 0x00007fffec38b89d in PetscDeviceContextSetupGlobalContext_Private ()
at src/sys/objects/device/interface/dcontext.cxx:674
#33 PetscDeviceContextGetCurrentContext (dctx=0x7fffffff4a78) at
src/sys/objects/device/interface/dcontext.cxx:705
#34 0x00007fffec4a2a16 in PetscKokkosInitializeCheck () at
src/sys/objects/kokkos/kinit.kokkos.cxx:31
#35 0x00007fffec6c7f61 in VecCreate_SeqKokkos (v=0xe787f0) at
src/vec/vec/impls/seq/kokkos/veckok.kokkos.cxx:1142
#36 0x00007fffec58d37c in VecSetType (vec=0xe787f0, method=<optimized out>)
at src/vec/vec/interface/vecreg.c:92
#37 0x00007fffec6ac017 in VecCreate_Kokkos (v=0xe787f0) at
src/vec/vec/impls/mpi/kokkos/mpikok.kokkos.cxx:476
#38 0x00007fffec58d37c in VecSetType (vec=0xe787f0, method=<optimized out>)
#39 0x00007fffecbc7d75 in DMCreateGlobalVector_Section_Private
(dm=0xe068a0, vec=0x7fffffff5d80) at src/dm/interface/dmi.c:57
#40 0x00007fffece8d6a0 in DMCreateGlobalVector_p4est (dm=0xe0ab40,
vec=0x7fffffff5d80) at src/dm/impls/forest/p4est/pforest.h:4929
#41 0x00007fffecba5d45 in DMCreateGlobalVector (dm=0xe068a0, vec=0x0,
vec at entry=0x7fffffff5d80) at src/dm/interface/dm.c:997
#42 0x00007fffed4292d1 in DMPlexLandauCreateVelocitySpace (comm=1140850688,
dim=2, prefix=<optimized out>, X=X at entry=0x7fffffff5df8,
J=J at entry=0x7fffffff5e40,
pack=pack at entry=0x7fffffff5e60) at src/ts/utils/dmplexlandau/plexland.c:2086
#43 0x0000000000205063 in main (argc=63, argv=0x7fffffff6368) at ex2.c:679
(gdb)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220524/a60f373d/attachment.html>
