[petsc-dev] Telescope usage
    Dave May
    dave.mayhem23 at gmail.com
    Tue May 17 04:50:20 CDT 2022
Hi Loic,
Can you confirm if your problem has stored state which needs to be
repartitioned?
Dave
On Tue 17. May 2022 at 09:07, Loic Gouarin <loic.gouarin at polytechnique.edu>
wrote:
> Le 17/05/2022 à 01:43, Dave May a écrit :
> On Tue, 17 May 2022 at 00:12, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, May 16, 2022 at 9:59 AM Loic Gouarin <
>> loic.gouarin at polytechnique.edu> wrote:
>>> Le 16/05/2022 à 21:54, Barry Smith a écrit :
>>> On May 16, 2022, at 3:50 PM, Loic Gouarin <
>>> Thanks Barry for your quick reply.
>>> Le 16/05/2022 à 21:41, Barry Smith a écrit :
>>>   Loic,
>>>     From your code it looks like you are using a DM. Is it a DMDA or a
>>> shell DM? If it is a DMDA then the process is intended to be pretty
>>> straightforward. PCTELESCOPE should create a new DMDA that has the same
>>> properties as the coarse grid DMDA but lives on a smaller number of ranks.
>>> From this you can just provide multiple levels of coarsening of the DMDA to
>>> produce the smaller multigrid problems.
>>> It's a DMDA. So what you mean is to take the KSP of PCTELESCOPE, get the
>>> DM which is the same of the coarse grid and build all the levels as
>>> previously for the levels of PCTELESCOPE ?
>>>   Yes, I think you should be able to pull out of the coarse level PC (on
>>> the subset of ranks) a DM that and then setup coarse levels from that. But
>>> you need to look at an example that that uses telescope and probably even
>>> the telescope code itself to see all the details. I don't know them anymore.
>>> I looked at the source code but It didn't help. I will try to explain
>>> more clearly my experiments to understand what I make wrong and you can
>>> help more easily.
>> Hi Loic!
>> Here is my guess. When TELESCOPE redistributes the coarse grid DMDA, it
>> creates a new DMDA and copies over all the information it can see. However,
>> I think you may have state that is attached to the old DMDA that is not
>> getting redistributed. If this is true, I can help you write a hook that
>> redistributes that state when TELESCOPE maps between distributions.
> If you have state you need to propagate between different communicators,
> you will have to use the telescope type which is internally is referred to
> as
> TELESCOPE_COARSEDM
> To activate this type you need the option
> -pc_telescope_use_coarse_dm
> Or to call PCTelescopeSetUseCoarseDM()
> The assumptions of usng this options are described here
> https://petsc.org/main/docs/manualpages/PC/PCTelescopeSetUseCoarseDM
> and source associated with the COARSEDM
> https://petsc.org/main/src/ksp/pc/impls/telescope/telescope_coarsedm.c.html
> Using TELESCOPE_COARSEDM you will have access to the hooks Matt is
> referring to.
> Thanks Matthew and Dave.
> I used TELESCOPE_COARSEDM in my previous tests but it tells me that "Zero
> instances of a coarse DM were found". And indeed, my coarse solver only has
> the DM on the coarse mesh and not on the fine level with a coarse DM
> atttached. I think it's because I use DMKSPSetComputeOperators to create
> the KSP on each level.
> So for now, I just added
> KSP coarse;
> ierr = PCMGGetCoarseSolve(pc_i, &coarse);CHKERRQ(ierr);
> PC pc_coarse;
> ierr = KSPGetPC(coarse, &pc_coarse);CHKERRQ(ierr);
> ierr = PCSetType(pc_coarse, PCTELESCOPE);CHKERRQ(ierr);
> ierr = PCTelescopeSetUseCoarseDM(pc_coarse, PETSC_TRUE);CHKERRQ(ierr);
> but it's not enough.
> Cheers,
> Loic
> Cheers,
> Dave
>>    Thanks,
>>      Matt
>>> Thanks,
>>> Loic
>>>   Barry
>>>    Can you let us know more details of what exactly goes wrong with
>>> attempts? It is likely straightforward to get things working, perhaps due
>>> to our unclear documentation.
>>> I essentially have wrong state or NULL matrices into the PCTELESCOPE.
>>> Loic
>>>   Barry
>>> On May 16, 2022, at 3:28 PM, Loic Gouarin <
>>> Hello,
>>> I could have posted my message on the user list but it seems to me that
>>> it's more in the petsc development part. Don't hesitate to tell me if I'm
>>> wrong.
>>> I am developing a code called cafes that studies fluid-particle
>>> interactions in a Stokes fluid. For that, we implemented the whole solver
>>> in matrix free on a cartesian grid. The preconditioner is naturally a
>>> geometrical multigrid for the velocity. The set of matrix free for each
>>> level is set by hand (I worked with Matthew on this a long time ago now!).
>>> I would have liked to implement telescope on this part. I started it but
>>> I didn't get out of it. So I would like to have your help.
>>> What I tried to do was to describe my classical multigrid up to a level
>>> N1 and then take the coarse solver and apply the telescope preconditioner
>>> to it up to a level N2. I don't know if this is the best way but it seemed
>>> the most intuitive. The problem is that I could not get the coarse matrix
>>> because the setup is not done yet (I use a DMKSPSetComputeOperators for the
>>> matrices).
>>> The construction of the matrix free for each level is here:
>>> https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L59-L88
>>> The description of the Stokes preconditioner is described here :
>>> https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L109-L162
>>> I have tried multiple implementations without success. For me, the start
>>> is to add at line 105 something like
>>> KSP coarse;
>>> PC pc_coarse;
>>> Then, to create the several matrices of the levels of TELESCOPE, I
>>> thought using the same process as before with DMKSPSetComputeOperators. But
>>> it doesn't work...
>>> Could you tell me how I can make it work ?
>>> Thanks,
>>> Loic
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220517/7fadaa97/attachment.html>
