[petsc-dev] Telescope usage
    Dave May
    dave.mayhem23 at gmail.com
    Mon May 16 18:43:06 CDT 2022
On Tue, 17 May 2022 at 00:12, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 16, 2022 at 9:59 AM Loic Gouarin <
> loic.gouarin at polytechnique.edu> wrote:
>> Le 16/05/2022 à 21:54, Barry Smith a écrit :
>> On May 16, 2022, at 3:50 PM, Loic Gouarin <loic.gouarin at polytechnique.edu>
>> wrote:
>> Thanks Barry for your quick reply.
>> Le 16/05/2022 à 21:41, Barry Smith a écrit :
>>   Loic,
>>     From your code it looks like you are using a DM. Is it a DMDA or a
>> shell DM? If it is a DMDA then the process is intended to be pretty
>> straightforward. PCTELESCOPE should create a new DMDA that has the same
>> properties as the coarse grid DMDA but lives on a smaller number of ranks.
>> From this you can just provide multiple levels of coarsening of the DMDA to
>> produce the smaller multigrid problems.
>> It's a DMDA. So what you mean is to take the KSP of PCTELESCOPE, get the
>> DM which is the same of the coarse grid and build all the levels as
>> previously for the levels of PCTELESCOPE ?
>>   Yes, I think you should be able to pull out of the coarse level PC (on
>> the subset of ranks) a DM that and then setup coarse levels from that. But
>> you need to look at an example that that uses telescope and probably even
>> the telescope code itself to see all the details. I don't know them anymore.
>> I looked at the source code but It didn't help. I will try to explain
>> more clearly my experiments to understand what I make wrong and you can
>> help more easily.
>> Hi Loic!
> Here is my guess. When TELESCOPE redistributes the coarse grid DMDA, it
> creates a new DMDA and copies over all the information it can see. However,
> I think you may have state that is attached to the old DMDA that is not
> getting redistributed. If this is true, I can help you write a hook that
> redistributes that state when TELESCOPE maps between distributions.
If you have state you need to propagate between different communicators,
you will have to use the telescope type which is internally is referred to
as
TELESCOPE_COARSEDM
To activate this type you need the option
-pc_telescope_use_coarse_dm
Or to call PCTelescopeSetUseCoarseDM()
The assumptions of usng this options are described here
https://petsc.org/main/docs/manualpages/PC/PCTelescopeSetUseCoarseDM
and source associated with the COARSEDM
https://petsc.org/main/src/ksp/pc/impls/telescope/telescope_coarsedm.c.html
Using TELESCOPE_COARSEDM you will have access to the hooks Matt is
referring to.
Cheers,
Dave
>    Thanks,
>      Matt
>> Thanks,
>> Loic
>>   Barry
>>    Can you let us know more details of what exactly goes wrong with
>> attempts? It is likely straightforward to get things working, perhaps due
>> to our unclear documentation.
>> I essentially have wrong state or NULL matrices into the PCTELESCOPE.
>> Loic
>>   Barry
>> On May 16, 2022, at 3:28 PM, Loic Gouarin <loic.gouarin at polytechnique.edu>
>> wrote:
>> Hello,
>> I could have posted my message on the user list but it seems to me that
>> it's more in the petsc development part. Don't hesitate to tell me if I'm
>> wrong.
>> I am developing a code called cafes that studies fluid-particle
>> interactions in a Stokes fluid. For that, we implemented the whole solver
>> in matrix free on a cartesian grid. The preconditioner is naturally a
>> geometrical multigrid for the velocity. The set of matrix free for each
>> level is set by hand (I worked with Matthew on this a long time ago now!).
>> I would have liked to implement telescope on this part. I started it but
>> I didn't get out of it. So I would like to have your help.
>> What I tried to do was to describe my classical multigrid up to a level
>> N1 and then take the coarse solver and apply the telescope preconditioner
>> to it up to a level N2. I don't know if this is the best way but it seemed
>> the most intuitive. The problem is that I could not get the coarse matrix
>> because the setup is not done yet (I use a DMKSPSetComputeOperators for the
>> matrices).
>> The construction of the matrix free for each level is here:
>> https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L59-L88
>> The description of the Stokes preconditioner is described here :
>> https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L109-L162
>> I have tried multiple implementations without success. For me, the start
>> is to add at line 105 something like
>> KSP coarse;
>> ierr = PCMGGetCoarseSolve(pc_i, &coarse);CHKERRQ(ierr);
>> PC pc_coarse;
>> ierr = KSPGetPC(coarse, &pc_coarse);CHKERRQ(ierr);
>> ierr = PCSetType(pc_coarse, PCTELESCOPE);CHKERRQ(ierr);
>> Then, to create the several matrices of the levels of TELESCOPE, I
>> thought using the same process as before with DMKSPSetComputeOperators. But
>> it doesn't work...
>> Could you tell me how I can make it work ?
>> Thanks,
>> Loic
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220517/0b8fabec/attachment.html>
