[petsc-dev] Telescope usage
    Barry Smith
    bsmith at petsc.dev
    Mon May 16 14:54:56 CDT 2022
> On May 16, 2022, at 3:50 PM, Loic Gouarin <loic.gouarin at polytechnique.edu> wrote:
> Thanks Barry for your quick reply.
> Le 16/05/2022 à 21:41, Barry Smith a écrit :
>>   Loic,
>>     From your code it looks like you are using a DM. Is it a DMDA or a shell DM? If it is a DMDA then the process is intended to be pretty straightforward. PCTELESCOPE should create a new DMDA that has the same properties as the coarse grid DMDA but lives on a smaller number of ranks. From this you can just provide multiple levels of coarsening of the DMDA to produce the smaller multigrid problems.
> It's a DMDA. So what you mean is to take the KSP of PCTELESCOPE, get the DM which is the same of the coarse grid and build all the levels as previously for the levels of PCTELESCOPE ?
  Yes, I think you should be able to pull out of the coarse level PC (on the subset of ranks) a DM that and then setup coarse levels from that. But you need to look at an example that that uses telescope and probably even the telescope code itself to see all the details. I don't know them anymore.
  Barry
>>    Can you let us know more details of what exactly goes wrong with attempts? It is likely straightforward to get things working, perhaps due to our unclear documentation.
> I essentially have wrong state or NULL matrices into the PCTELESCOPE.
> Loic
>>   Barry
>>> On May 16, 2022, at 3:28 PM, Loic Gouarin <loic.gouarin at polytechnique.edu <mailto:loic.gouarin at polytechnique.edu>> wrote:
>>> Hello,
>>> I could have posted my message on the user list but it seems to me that it's more in the petsc development part. Don't hesitate to tell me if I'm wrong.
>>> I am developing a code called cafes that studies fluid-particle interactions in a Stokes fluid. For that, we implemented the whole solver in matrix free on a cartesian grid. The preconditioner is naturally a geometrical multigrid for the velocity. The set of matrix free for each level is set by hand (I worked with Matthew on this a long time ago now!).
>>> I would have liked to implement telescope on this part. I started it but I didn't get out of it. So I would like to have your help.
>>> What I tried to do was to describe my classical multigrid up to a level N1 and then take the coarse solver and apply the telescope preconditioner to it up to a level N2. I don't know if this is the best way but it seemed the most intuitive. The problem is that I could not get the coarse matrix because the setup is not done yet (I use a DMKSPSetComputeOperators for the matrices).
>>> The construction of the matrix free for each level is here: https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L59-L88 <https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L59-L88>
>>> The description of the Stokes preconditioner is described here : https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L109-L162 <https://github.com/gouarin/cafes/blob/master/cafes/problem/stokes.hpp#L109-L162>
>>> I have tried multiple implementations without success. For me, the start is to add at line 105 something like
>>> KSP coarse;
>>> ierr = PCMGGetCoarseSolve(pc_i, &coarse);CHKERRQ(ierr);
>>> PC pc_coarse;
>>> ierr = KSPGetPC(coarse, &pc_coarse);CHKERRQ(ierr);
>>> ierr = PCSetType(pc_coarse, PCTELESCOPE);CHKERRQ(ierr);
>>> Then, to create the several matrices of the levels of TELESCOPE, I thought using the same process as before with DMKSPSetComputeOperators. But it doesn't work...
>>> Could you tell me how I can make it work ?
>>> Thanks,
>>> Loic
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220516/d88c424b/attachment.html>
