[petsc-dev] Manual page improvements! (Docs MRs to main until PETSc 3.18 is released)
    Satish Balay
    balay at mcs.anl.gov
    Wed May  4 08:12:42 CDT 2022
On Wed, 4 May 2022, Patrick Sanan wrote:
> Unlike most previous docs changes, this has only been done on the main
> branch. So, **until PETSc 3.18 is released, make documentation MRs to main**,
> unless fixing something particularly critical on the release branch, or
> making a change which you've tested won't cause (serious) merge conflicts
> when release is merged into main.
This is true for non-doc fixes as-well. [higher probability of merge conflicts and other issues]
One way to check for potential (serious) merge conflicts is:
- always make the needed change to main branch
- once the fix is complete - attempt a rebase onto release
git fetch && git rebase --onto origin/release origin/main
- If this rebase is clean - then it could be an MR to release [with an easy merge - back to main]
Satish
