[petsc-dev] PETSc amg solver with gpu seems run slowly
Justin Chang
jychang48 at gmail.com
Mon Mar 28 11:35:55 CDT 2022
Hi Qi, Mark,
My colleague Suyash Tandon has almost completed a PETSc HIP port
(essentially a hipification of the CUDA port) and has been trying to test
it on the same OpenFOAM 3D Lid-driven case. It would be interesting to see
what the optimal HYPRE parameters are as we could experiment from the AMD
side.
Justin
On Mon, Mar 28, 2022 at 10:28 AM Qi Yang <qiyang at oakland.edu> wrote:
> Hi Mark,
> Sure, I will try a 3D Lid-driven case by combining OpenFOAM, PETSc and
> HYPRE, let's see what would happen.
> Kind regards,
> Qi
> On Mon, Mar 28, 2022 at 11:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Hi Qi, these are good discussions and data and we like to share, so let's
>> keep this on the list.
>> * I would suggest you use a 3D test. This is more relevant to what HPC
>> applications do.
>> * In my experience, hypre's default parameters are tuned for 2D low order
>> problems like this so I would start with the defaults. I think they should
>> be fine for 3D also.
>> * As I think I said before we have an AMGx interface under
>> development and I heard yesterday that it should not be long until it is
>> available. It would be great if you could test that and we can work with
>> the NVIDIA developer to optimize it. We will let you know when
>> its available.
>> Cheers,
>> Mark
>> On Mon, Mar 28, 2022 at 10:44 AM Qi Yang <qiyang at oakland.edu> wrote:
>>> Hi Mark and Barry,
>>> Really appreciate your explanation about the setup process, those days I
>>> tried to use the HYPRE amg solver to replace the original amg solver in
>>> PETSc.
>>> The solver settings of HYPRE are as follows:
>>> mpiexec -n 1 ./ex50 -da_grid_x 3000 -da_grid_y 3000 -ksp_type cg
>>> -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_max_iter 1
>>> -pc_hypre_boomeramg_strong_threshold 0.7
>>> -pc_hypre_boomeramg_grid_sweeps_up 1 -pc_hypre_boomeramg_grid_sweeps_down 1
>>> -pc_hypre_boomeramg_agg_nl 2 -pc_hypre_boomeramg_agg_num_paths 1
>>> -pc_hypre_boomeramg_max_levels 25 *-pc_hypre_boomeramg_coarsen_type
>>> PMIS* -pc_hypre_boomeramg_interp_type ext+i -pc_hypre_boomeramg_P_max 2
>>> -pc_hypre_boomeramg_truncfactor 0.2 -vec_type cuda -mat_type aijcusparse
>>> -ksp_monitor -ksp_view -log-view
>>> [image: PMIS.PNG]
>>> The interesting part is that I choose the coarsen type as PMIS, through
>>> the code, you can find only PMIS has GPU codes(Host and Device).
>>> * HYPRE does reduce the solution time from 20s to 8s
>>> * The memory mapping process is found inside the solver process, which
>>> causes several gaps in the following NVIDIA Nsight System profile, I am not
>>> sure what does it mean,
>>> [image: image.png]
>>> I am really interested to do some benchmarks by using hypre amg solver,
>>> actually, I already connected OpenFOAM, PETSc, HYPRE and AMGX together by
>>> using the API
>>> petsc4foam(
>>> https://develop.openfoam.com/modules/external-solver/-/tree/amgxwrapper/src/petsc4Foam),
>>> I prefer to use PETSc as the base matrix solver for possible HIP code
>>> implementation in the future, that way, I can compare the difference
>>> between NVIDIA and AMD GPU. It seems there are many benchmark cases I can
>>> do in the future.
>>> Regards,
>>> Qi
>>> On Wed, Mar 23, 2022 at 9:39 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> A few points, but first this is a nice start. If you are interested in
>>>> working on benchmarking that would be great. If so, read on.
>>>> * Barry pointed out the SOR issues that are thrashing the
>>>> memory system. This solve would run faster on the CPU (maybe, 9M eqs is a
>>>> lot).
>>>> * Most applications run for some time doing 100-1,000 and more solves
>>>> with one configuration and this amortizes the setup costs for each mesh.
>>>> What I call "mesh setup" cost.
>>>> * Many applications are nonlinear and use a full Newton solver that
>>>> does a "matrix setup" for each solve, but many applications can also
>>>> amortize this matrix setup (PtAP stuff in the output, which is small for 2D
>>>> problem but can be large for 3D problems)
>>>> * Now hypre's mesh setup is definitely better that GAMG's and AMGx is
>>>> out of this world.
>>>> - AMGx is the result of a serious development effort by NVIDIA about
>>>> 15 years ago with many 10's of NVIDIA developer years in it (I am guessing
>>>> but I know it was a serious effort for a few years)
>>>> + We are currently working with the current AMG developer, Matt, to
>>>> provide an AMGx interface in PETSc, like hypre (DOE does not like us
>>>> working with non-portable solvers but AMGx is very good)
>>>> * Hypre and AMGx use "classic" AMG, which is like geometric multigrid
>>>> (fast) for M-matrices (very low order Laplacians, like ex50).
>>>> * GAMG uses "smoothed aggregation" AMG because this algorithm has
>>>> better theoretical properties for high order and elasticity problems and
>>>> the algorithm's implementations and default parameters have been optimized
>>>> for these types of problems.
>>>> It would be interesting to add Hypre to your study (Ex50) and add a
>>>> high order 3D elasticity problem (eg, snes/tests/ex13, or Jed Brown has
>>>> some nice elasticity problems).
>>>> If you are interested we can give you Hypre parameters for elasticity
>>>> problems.
>>>> I have no experience with AMGx on elasticity but the NVIDIA developer
>>>> is available and can be looped in.
>>>> For that matter we could bring the main hypre developer, Ruipeng, in as
>>>> well.
>>>> I would also suggest timing the setup (you can combine mesh and matrix
>>>> if you like) and solve phase separately. ex13 does this and we should find
>>>> another 5-point stencil example that does this if ex50 does not.
>>>> BTW, I have been intending to write a benchmarking paper this year with
>>>> Matt and Ruipeng, but I am just not getting around to it ...
>>>> If you want to lead a paper and the experiments, we can help optimize
>>>> and tune our solvers, setup tests, write background material, etc.
>>>> Cheers,
>>>> Mark
>>>> On Tue, Mar 22, 2022 at 12:30 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>> Indeed PCSetUp is taking most of the time (79%). In the version of
>>>>> PETSc you are running it is doing a great deal of the setup work on the
>>>>> CPU. You can see there is a lot of data movement between the CPU and GPU
>>>>> (in both directions) during the setup; 64 1.91e+03 54 1.21e+03 90
>>>>> Clearly, we need help in porting all the parts of the GAMG setup that
>>>>> still occur on the CPU to the GPU.
>>>>> Barry
>>>>> On Mar 22, 2022, at 12:07 PM, Qi Yang <qiyang at oakland.edu> wrote:
>>>>> Dear Barry,
>>>>> Your advice is helpful, now the total time reduce from 30s to 20s(now
>>>>> all matrix run on gpu), actually I have tried other settings for amg
>>>>> predicontioner, seems not help that a lot, like -pc_gamg_threshold 0.05
>>>>> -pc_gamg_threshold_scale 0.5.
>>>>> it seems the key point is the PCSetup process, from the log, it takes
>>>>> the most time, and we can find from the new nsight system analysis, there
>>>>> is a big gap before the ksp solver starts, seems like the PCSetup process,
>>>>> not sure, am I right?
>>>>> <3.png>
>>>>> PCSetUp 2 1.0 1.5594e+01 1.0 3.06e+09 1.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 79 78 0 0 0 79 78 0 0 0 196 8433 64
>>>>> Regards,
>>>>> Qi
>>>>> On Tue, Mar 22, 2022 at 10:44 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>> It is using
>>>>>> MatSOR 369 1.0 9.1214e+00 1.0 7.32e+09 1.0 0.0e+00
>>>>>> 0.0e+00 0.0e+00 29 27 0 0 0 29 27 0 0 0 803 0 0
>>>>>> 0.00e+00 565 1.35e+03 0
>>>>>> which runs on the CPU not the GPU hence the large amount of time in
>>>>>> memory copies and poor performance. We are switching the default to be
>>>>>> Chebyshev/Jacobi which runs completely on the GPU (may already be switched
>>>>>> in the main branch).
>>>>>> You can run with -mg_levels_pc_type jacobi You should then see
>>>>>> almost the entire solver running on the GPU.
>>>>>> You may need to tune the number of smoothing steps or other
>>>>>> parameters of GAMG to get the faster solution time.
>>>>>> Barry
>>>>>> On Mar 22, 2022, at 10:30 AM, Qi Yang <qiyang at oakland.edu> wrote:
>>>>>> To whom it may concern,
>>>>>> I have tried petsc ex50(Possion) with cuda, ksp cg solver and
>>>>>> gamg precondition, however, it run for about 30s. I also tried NVIDIA AMGX
>>>>>> with the same solver and same grid (3000*3000), it only took 2s. I used
>>>>>> nsight system software to analyze those two cases, found petsc took much
>>>>>> time in the memory process (63% of total time, however, amgx only took
>>>>>> 19%). Attached are screenshots of them.
>>>>>> The petsc command is : mpiexec -n 1 ./ex50 -da_grid_x 3000
>>>>>> -da_grid_y 3000 -ksp_type cg -pc_type gamg -pc_gamg_type agg
>>>>>> -pc_gamg_agg_nsmooths 1 -vec_type cuda -mat_type aijcusparse -ksp_monitor
>>>>>> -ksp_view -log-view
>>>>>> The log file is also attached.
>>>>>> Regards,
>>>>>> Qi
>>>>>> <1.png>
>>>>>> <2.png>
>>>>>> <log.PETSc_cg_amg_ex50_gpu_cuda>
>>>>>> <log.PETSc_cg_amg_jacobi_ex50_gpu_cuda>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220328/4840f649/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220328/4840f649/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220328/4840f649/attachment-0003.png>
