[petsc-dev] petsc release plan for Mar/2022
Fri Mar 25 10:27:58 CDT 2022
On Fri, Mar 25, 2022 at 10:37 AM Satish Balay via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> A reminder!
> Currently I see the following MRs with v3.17-release milestone
> Satish
>     Cleaning up some Plex I/O
>     !5013 · created 2 days ago by Matthew Knepley   v3.17-release
Waiting for merge.
>     Change a bunch of PetscCheckFalse() to PetscCheck() in pc
>     !5000 · created 3 days ago by Barry Smith   v3.17-release
>     Support COO for MatHypre
>     !5023 · created 10 hours ago by Junchao Zhang   v3.17-release
>     Plex: Enhance extrusion
>     !5019 · created 21 hours ago by Matthew Knepley   v3.17-release
Waiting for approval by Jed. CI has passed.
      Matt
>     Draft: SNES: delete empty examples   0 of 2 tasks completed
>     !5024 · created 4 hours ago by Vaclav Hapla   v3.17-release
>     PetscSection: Lazy maxDof calculation.
>     !5025 · created 3 hours ago by Vaclav Hapla   v3.17-release
>     Mat_MPIAIJCUSPARSE does not need to have its own stream or cuSparse
> handle
>     !5020 · created 17 hours ago by Junchao Zhang   v3.17-release
>     Draft: configure: update packages for 3.17.0
>     !4982 · created 1 week ago by Pierre Jolivet   v3.17-release
>     Draft: release: set petsc v3.17.0 strings
>     !5015 · created 1 day ago by Satish Balay   v3.17-release
>     Remove use of PetscCheckFalse() on a subset of examples
>     !5006 · created 2 days ago by Barry Smith   v3.17-release
>     dmnetwork rebalance vertices
>     !4945 · created 2 weeks ago by Getnet Betrie   v3.17-release
> On Thu, 3 Mar 2022, Satish Balay via petsc-dev wrote:
> > All,
> > Its time for another PETSc release - due end of March.
> > For this release [3.17], lets work with the following dates:
> > - feature freeze: March 28 say 5PM EST
> > - release: March 30 say 5PM EST
> > Merges after freeze should contain only fixes that would normally be
> acceptable to "release" work-flow.
> > I've created a new milestone 'v3.17-release'. So if you are working on a
> MR with the goal of merging before release - its best to use this tag with
> the MR.
> > And it would be good to avoid merging large changes at the last minute.
> And not have merge requests stuck in need of reviews, testing and other
> necessary tasks.
> > And I would think the testing/CI resources would get stressed in this
> timeframe - so it would be good to use them judiciously if possible.
> > - if there are failures in stage-2 or 3 - and its no longer necessary to
> complete all the jobs - one can 'cancel' the pipeline.
> > - if a fix needs to be tested - one can first test with only the failed
> jobs (if this is known) - before doing a full test pipeline. i.e:
> >    - use the automatically started and paused 'merge-request' pipeline
> (or start new 'web' pipeline, and cancel it immediately)
> >    - now toggle only the jobs that need to be run
> >    - [on success of the selected jobs] if one wants to run the full
> pipeleine - click 'retry' - and the remaining canceled jobs should now get
> scheduled.
> > Thanks,
> > Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220325/69768f70/attachment.html>
