[petsc-dev] PETSc amg solver with gpu seems run slowly
Qi Yang
qiyang at oakland.edu
Tue Mar 22 09:30:50 CDT 2022
To whom it may concern,
I have tried petsc ex50(Possion) with cuda, ksp cg solver and
gamg precondition, however, it run for about 30s. I also tried NVIDIA AMGX
with the same solver and same grid (3000*3000), it only took 2s. I used
nsight system software to analyze those two cases, found petsc took much
time in the memory process (63% of total time, however, amgx only took
19%). Attached are screenshots of them.
The petsc command is : mpiexec -n 1 ./ex50 -da_grid_x 3000 -da_grid_y 3000
-ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
-vec_type cuda -mat_type aijcusparse -ksp_monitor -ksp_view -log-view
The log file is also attached.
Qi
[image: 1.png]
[image: 2.png]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220322/bf1d440c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220322/bf1d440c/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220322/bf1d440c/attachment-0003.png>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220322/bf1d440c/attachment-0001.obj>
