[petsc-dev] MatMPIAIJGetLocalMat problem with GPUs
Mark Adams mfadams at lbl.gov
Sat Jun 25 08:13:28 CDT 2022
On Fri, Jun 24, 2022 at 1:54 PM Barry Smith <bsmith at petsc.dev> wrote:
> On Jun 24, 2022, at 1:38 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I am rearranging the code for clarity from the repo but I have:
>   PetscBool is_dev_ptrs;
>   PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_INITIAL_MATRIX, &amgx->localA));
>   PetscCall(PetscObjectTypeCompareAny((PetscObject)amgx->localA,
> &is_dev_ptrs, MATAIJCUSPARSE, MATSEQAIJCUSPARSE, MATMPIAIJCUSPARSE, ""));
>   PetscPrintf(PETSC_COMM_SELF,"*checking against mataijcusparse
> amgx->localA = %d*\n",is_dev_ptrs);
>   PetscCall(PetscObjectTypeCompareAny((PetscObject)Pmat, &is_dev_ptrs,
>   PetscPrintf(PETSC_COMM_SELF,"*checking against mataijcusparse Pmat = %d*
> \n",is_dev_ptrs);
> And it seems to show that MatMPIAIJGetLocalMat takes a mpiaijcusparse Mat
> and returns an seqaij mat (see below):
>  Yes, this is how it currently behaves as Stefano has indicated. Thus it
> is not currently directly suitable for use with GPUs. As Stefano has
> indicated it has be revised to handle mpiaijcusparse matrices correctly
> in the same way that MatMPIAIJGetLocalMatMerge has been revised for GPUs.
OK, sorry, I did not understand that this is not supported. We need a
MatMPIAIJCusparseGetLocalMatMerge (I read this as supported with "hstack"
format, unsorted?, by Stefano)
What is the best way to proceed? Should we just convert to amgx->localA
to mpiaijcusparse if Pmat is a cusparse matrix?
If so, should this code go in amgx or
MatMPIAIJGetLocalMat(MAT_INITIAL_MATRIX) ?
Or should I add a MatMPIAIJCusparseGetLocalMatMerge that simply wraps these
two calls for now?
> AMGX version 2.2.0.132-opensource
> Built on Jun 24 2022, 09:21:43
> Compiled with CUDA Runtime 11.5, using CUDA driver 11.5
> *checking against mataijcusparse amgx->localA = 0checking against
> mataijcusparse Pmat = 1*
> localA_name seqaij
> Pmat_name mpiaijcusparse
> Matt's existing testing code (below) then shows the types that conform
> with these tests and prints that I added.
>   // XXX DEBUG REMOVE
>   const char* localA_name;
>   PetscObjectGetType((PetscObject)amgx->localA, &localA_name);
>   PetscPrintf(PETSC_COMM_SELF,"localA_name %s\n", localA_name);
>   const char* Pmat_name;
>   PetscObjectGetType((PetscObject)Pmat, &Pmat_name);
>   PetscPrintf(PETSC_COMM_SELF,"Pmat_name %s\n", Pmat_name);
> On Fri, Jun 24, 2022 at 10:00 AM Barry Smith <bsmith at petsc.dev> wrote:
>> On Jun 24, 2022, at 8:58 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> And before we move to the MR, I think Matt found a clear problem:
>> * PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_REUSE_MATRIX, &amgx->localA));
>> returns "localA seqaij"
>> * And, oddly, PetscCall(MatSeqAIJGetArrayRead(amgx->localA,
>> &amgx->values)); returns:
>> "it seems to detect that the pointer is a device mapped pointer but that
>> it is invalid"
>>   It does not return a device mapped pointer, it returns a valid host
>> pointer only. MatSeqAIJGetArrayRead() is intended to only return a host
>> pointer, it cannot return a device pointer. MatSeqAIJCusparseGetArrayRead()
>> returns device pointers and should be used for this purpose.
>> Matt, lets just comment out the REUSE line and add another INITIAL line
>> (destroying the old Mat of course), and lets press on.
>>   Looking at the code there is no way that simply using INITIAL instead
>> of REUSE will make a code that does not work on the GPU run on the GPU. The
>> MatMPIAIJGetLocalMat() returns only a MATSEQAIJ matrix regardless of
>> the INITIAL versus REUSE and one can never get a device pointer from a
>> non-GPU matrix.
>>    As noted by Stefano, the code either needs to use
>> MatMPIAIJGetLocalMatMerge () which does return a CUSPARSE matrix (but
>> the columns are not supported) or MatMPIAIJGetLocalMat()
>> needs to be updated to return a CUSPARSE matrix when the input MPI matrix
>> is a CUSPARSE matrix.
>> We can keep the debugging code for now.
>> We (PETSc) can work on this independently,
>> Thanks,
>> Mark
>> On Fri, Jun 24, 2022 at 8:51 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> I am not seeing this response, I see my "hstack" comment last.
>>> https://gitlab.com/petsc/petsc/-/merge_requests/4323
>>> On Thu, Jun 23, 2022 at 4:37 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>  I have responded in the MR, which has all the context and the code.
>>>> Please move this conversation from petsc-dev to the MR. Note you can use
>>>> the little cartoon cloud symbol (upper write of the sub window with my
>>>> text)  to reply to my post and keep everything in a thread for clarity.
>>>>   We are confused because it seems you are trying a variety of things
>>>> and we don't know how the different things you tried resulted in the
>>>> multiple errors you reported.
>>>> On Jun 23, 2022, at 3:59 PM, Matthew Martineau <mmartineau at nvidia.com>
>>>> wrote:
>>>> I checked in the changes and some debugging statements.
>>>> Then the call returns false. If we instead call
>>>> PetscObjectTypeCompareAny on Pmat then it returns true. If you print the
>>>> type of the matrices:
>>>> localA seqaij
>>>> Pmat mpiaijcusparse
>>>> If you subsequently call MatSeqAIJCUSPARSEGetArrayRead on localA then
>>>> it errors (presumably because of the type mismatch).
>>>> If we call MatSeqAIJGetArrayRead on localA and then pass the `values`
>>>> to AmgX it seems to detect that the pointer is a device mapped pointer but
>>>> that it is invalid.
>>>> PetscCall(MatSeqAIJGetArrayRead(amgx->localA, &amgx->values)); // Seems
>>>> to return invalid pointer, but I’ll investigate more
>>>> This doesn’t reproduce if we call:
>>>> &amgx->localA));
>>>> Pointer appears to be valid and we converge
>>>> Essentially all I want to achieve is that when we are parallel, we
>>>> fetch the local part of A and the device pointer to the matrix values from
>>>> that structure so that we can pass to AmgX. Preferring whichever API calls
>>>> are the most efficient.
>>>> *From:* Stefano Zampini <stefano.zampini at gmail.com>
>>>> *Sent:* 23 June 2022 20:55
>>>> *To:* Mark Adams <mfadams at lbl.gov>
>>>> *Cc:* Barry Smith <bsmith at petsc.dev>; For users of the development
>>>> version of PETSc <petsc-dev at mcs.anl.gov>; Matthew Martineau <
>>>> *Subject:* Re: [petsc-dev] MatMPIAIJGetLocalMat problem with GPUs
>>>> *External email: Use caution opening links or attachments*
>>>> The logic is wrong. It should check for MATSEQAIJCUSPARSE.
>>>> On Thu, Jun 23, 2022, 21:36 Mark Adams <mfadams at lbl.gov> wrote:
>>>> On Thu, Jun 23, 2022 at 3:02 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>   It looks like the current code copies the nonzero values to the CPU
>>>> from the MPI matrix (with the calls
>>>> PetscCall(MatSeqAIJGetArrayRead(mpimat->A,&aav));
>>>>   PetscCall(MatSeqAIJGetArrayRead(mpimat->B,&bav));, then copies them
>>>> into the CPU memory of the Seq matrix. When the matrix entries are next
>>>> accessed on the GPU it should automatically copy them down to the GPU.  So
>>>> the code looks ok even for GPUs. We'll need to see the full error message
>>>> with what the "invalid pointer" is.
>>>> I showed Matt how to peek into offloadmask and he found that it is a
>>>> host state, but this is not the issue. The access method should do the copy
>>>> to the device.
>>>> I am thinking the logic here might be wrong. (Matt fixed "VEC" -->
>>>> "MAT" in the comparison below).
>>>> Matt, is the issue that you are calling
>>>> *MatSeqAIJCUSPARSEGetArrayRead* and getting a host pointer?
>>>> I think the state of amgx->localA after the call to
>>>> MatSeqAIJCUSPARSEGetArrayRead should be "BOTH" because this copied the data
>>>> to the device so they are both valid and you should have device data.
>>>> 211   PetscBool is_dev_ptrs;
>>>> 212   PetscCall(PetscObjectTypeCompareAny((PetscObject)amgx->localA,
>>>> &is_dev_ptrs, VECCUDA, VECMPICUDA, VECSEQCUDA, ""));
>>>> 213
>>>> 214   if (is_dev_ptrs) {
>>>> *216     PetscCall(MatSeqAIJCUSPARSEGetArrayRead(amgx->localA,
>>>> &amgx->values));*217   } else {
>>>> 219     PetscCall(MatSeqAIJGetArrayRead(amgx->localA, &amgx->values));
>>>> 220   }
>>>>   Barry
>>>>  Yes this routine is terribly inefficient for GPU matrices, it needs to
>>>> be specialized to not use the GPU memory but that is a separate issue from
>>>> there being bugs in the current code.
>>>>   The code also seems to implicitly assume the parallel matrix has the
>>>> same nonzero pattern with a reuse. This should be checked with each use by
>>>> stashing the nonzero state of the matrix into the sequential matrix and
>>>> making sure the parallel matrix has that same stashed value each time.
>>>> Currently if one changes the nonzero matrix of the parallel matrix one is
>>>> likely to get random confusing crashes due to memory corruption. But likely
>>>> not the problem here.
>>>> On Jun 23, 2022, at 2:23 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> We have a bug in the AMGx test snes_tests-ex13_amgx in parallel.
>>>> Matt Martineau found that MatMPIAIJGetLocalMat worked in the first pass
>>>> in the code below, where the local matrix is created (INITIAL), but in the
>>>> next pass, when "REUSE" is used, he sees an invalid pointer.
>>>> Matt found that it does have offloadmask == CPU.
>>>> Maybe it is missing logic to put the output in same state as the input?
>>>> Any ideas on this or should I just dig into it?
>>>> Thanks,
>>>> bool partial_setup_allowed = (pc->setupcalled && pc->flag != DIFFERENT_NONZERO_PATTERN);
>>>> 199   if (amgx->nranks > 1) {
>>>> 200     if (partial_setup_allowed) {
>>>> 202       PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_REUSE_MATRIX, &amgx->localA)); // This path seems doesn't work by the time we reach AmgX API
>>>> 203     } else {
>>>> 205       PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_INITIAL_MATRIX, &amgx->localA)); // This path works
>>>> 206     }
>>>> 207   } else {
>>>> 208     amgx->localA = Pmat;
>>>> 209   }
>>>> 210
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220625/bb96f92b/attachment-0001.html>
