[petsc-dev] MatMPIAIJGetLocalMat problem with GPUs
Matthew Martineau mmartineau at nvidia.com
Thu Jun 23 14:59:30 CDT 2022
I checked in the changes and some debugging statements.
PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_REUSE_MATRIX, &amgx->localA));
PetscCall(PetscObjectTypeCompareAny((PetscObject)amgx->localA, &is_dev_ptrs, MATAIJCUSPARSE, MATSEQAIJCUSPARSE, MATMPIAIJCUSPARSE, ""));
Then the call returns false. If we instead call PetscObjectTypeCompareAny on Pmat then it returns true. If you print the type of the matrices:
localA seqaij
Pmat mpiaijcusparse
If you subsequently call MatSeqAIJCUSPARSEGetArrayRead on localA then it errors (presumably because of the type mismatch).
If we call MatSeqAIJGetArrayRead on localA and then pass the `values` to AmgX it seems to detect that the pointer is a device mapped pointer but that it is invalid.
PetscCall(MatSeqAIJGetArrayRead(amgx->localA, &amgx->values)); // Seems to return invalid pointer, but I’ll investigate more
This doesn’t reproduce if we call:
PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_INITIAL_MATRIX, &amgx->localA));
PetscCall(MatSeqAIJGetArrayRead(amgx->localA, &amgx->values)); // Pointer appears to be valid and we converge
Essentially all I want to achieve is that when we are parallel, we fetch the local part of A and the device pointer to the matrix values from that structure so that we can pass to AmgX. Preferring whichever API calls are the most efficient.
From: Stefano Zampini <stefano.zampini at gmail.com>
Sent: 23 June 2022 20:55
To: Mark Adams <mfadams at lbl.gov>
Cc: Barry Smith <bsmith at petsc.dev>; For users of the development version of PETSc <petsc-dev at mcs.anl.gov>; Matthew Martineau <mmartineau at nvidia.com>
Subject: Re: [petsc-dev] MatMPIAIJGetLocalMat problem with GPUs
External email: Use caution opening links or attachments
The logic is wrong. It should check for MATSEQAIJCUSPARSE.
On Thu, Jun 23, 2022, 21:36 Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
On Thu, Jun 23, 2022 at 3:02 PM Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
  It looks like the current code copies the nonzero values to the CPU from the MPI matrix (with the calls PetscCall(MatSeqAIJGetArrayRead(mpimat->A,&aav));
  PetscCall(MatSeqAIJGetArrayRead(mpimat->B,&bav));, then copies them into the CPU memory of the Seq matrix. When the matrix entries are next accessed on the GPU it should automatically copy them down to the GPU.  So the code looks ok even for GPUs. We'll need to see the full error message with what the "invalid pointer" is.
I showed Matt how to peek into offloadmask and he found that it is a host state, but this is not the issue. The access method should do the copy to the device.
I am thinking the logic here might be wrong. (Matt fixed "VEC" --> "MAT" in the comparison below).
Matt, is the issue that you are calling  MatSeqAIJCUSPARSEGetArrayRead and getting a host pointer?
I think the state of amgx->localA after the call to MatSeqAIJCUSPARSEGetArrayRead should be "BOTH" because this copied the data to the device so they are both valid and you should have device data.
211   PetscBool is_dev_ptrs;
212   PetscCall(PetscObjectTypeCompareAny((PetscObject)amgx->localA, &is_dev_ptrs, VECCUDA, VECMPICUDA, VECSEQCUDA, ""));
213
214   if (is_dev_ptrs) {
216     PetscCall(MatSeqAIJCUSPARSEGetArrayRead(amgx->localA, &amgx->values));
217   } else {
219     PetscCall(MatSeqAIJGetArrayRead(amgx->localA, &amgx->values));
220   }
  Barry
 Yes this routine is terribly inefficient for GPU matrices, it needs to be specialized to not use the GPU memory but that is a separate issue from there being bugs in the current code.
  The code also seems to implicitly assume the parallel matrix has the same nonzero pattern with a reuse. This should be checked with each use by stashing the nonzero state of the matrix into the sequential matrix and making sure the parallel matrix has that same stashed value each time. Currently if one changes the nonzero matrix of the parallel matrix one is likely to get random confusing crashes due to memory corruption. But likely not the problem here.
On Jun 23, 2022, at 2:23 PM, Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
We have a bug in the AMGx test snes_tests-ex13_amgx in parallel.
Matt Martineau found that MatMPIAIJGetLocalMat worked in the first pass in the code below, where the local matrix is created (INITIAL), but in the next pass, when "REUSE" is used, he sees an invalid pointer.
Matt found that it does have offloadmask == CPU.
Maybe it is missing logic to put the output in same state as the input?
Any ideas on this or should I just dig into it?
bool partial_setup_allowed = (pc->setupcalled && pc->flag != DIFFERENT_NONZERO_PATTERN);
199   if (amgx->nranks > 1) {
200     if (partial_setup_allowed) {
202       PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_REUSE_MATRIX, &amgx->localA)); // This path seems doesn't work by the time we reach AmgX API
203     } else {
205       PetscCall(MatMPIAIJGetLocalMat(Pmat, MAT_INITIAL_MATRIX, &amgx->localA)); // This path works
206     }
207   } else {
208     amgx->localA = Pmat;
209   }
210
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220623/fe03da4d/attachment-0001.html>
