[petsc-dev] Jacobi (smoothing) not staying on GPU
    Jose E. Roman
    jroman at dsic.upv.es
    Wed Jun  8 01:53:40 CDT 2022
Add an implementation of MatGetDiagonal_SeqAIJCUSPARSE(), which is missing. Use for example this: https://stackoverflow.com/questions/60311408/how-to-get-the-diagonal-of-a-sparse-matrix-in-cusparse
Jose
> El 8 jun 2022, a las 3:21, Mark Adams <mfadams at lbl.gov> escribió:
> I am looking at TS/SNES/KSP/GAMG solve with Landau, which is all on the GPU, but it looks like MatGetDiagonal (see attached), and to a lesser extent VecPointWiseMult (biggest red band on the right side under PCApply), are resulting in expensive CPU-GPU movement. MatGetDiagonal on the fine grid is taking about 10x the time of TFQMR/GAMG iteration.
> Attached is a view of this with CUDA and an nsys data file with Kokkos that is pretty much the same.
> Any thoughts on how to fix this?
> Thanks,
> Mark
> <Screen Shot 2022-06-07 at 8.31.20 PM.png><output_ex2_3d_kokkos.nsys-rep>
