[petsc-dev] test failure in main
    Satish Balay
    balay at mcs.anl.gov
    Fri Jul 29 20:16:04 CDT 2022
A fix is now merged to main. A *new* pipeline on the MR should work now.
Satish
On Fri, 29 Jul 2022, Barry Smith wrote:
>   I just reported this on the testing-ci slack channel one second ago. Looks like it was introduced with Matt's last merge.
> > On Jul 29, 2022, at 5:37 PM, Blaise Bourdin <bourdin at mcmaster.ca> wrote:
> > Hi,
> > I am trying to get a bunch of small MR through the test system without success. Right now, it looks like even the main branch does not pass the tests:
> > ./configure --CFLAGS='-Wimplicit-function-declaration -Wunused' --FFLAGS='-ffree-line-length-none -fallow-argument-mismatch -Wunused' --download-metis=1 --download-parmetis=1 --with-debugging=1 --with-shared-libraries=1 --with-x11=1
> > SiMini:petsc-main (main)$ make -f gmakefile test search="dm_impls_plex_tutorials-ex8_3d_q1_periodic_project"
> > Using MAKEFLAGS: search=dm_impls_plex_tutorials-ex8_3d_q1_periodic_project
> >        TEST monterey-gcc11.3-arm64-basic-g/tests/counts/dm_impls_plex_tutorials-ex8_3d_q1_periodic_project.counts
> > ok dm_impls_plex_tutorials-ex8_3d_q1_periodic_project
> > not ok diff-dm_impls_plex_tutorials-ex8_3d_q1_periodic_project # Error code: 1
> > #	10c10
> > #	<   marker: 1 strata with value/size (1 (36))
> > #	>   marker: 1 strata with value/size (1 (48))
> > # FAILED diff-dm_impls_plex_tutorials-ex8_3d_q1_periodic_project
> > # To rerun failed tests:
> > #     /opt/homebrew/bin/gmake -f gmakefile test test-fail=1
> > am I the only one to see this?
> > Regards,
> > Blaise
> > Tier 1 Canada Research Chair in Mathematical and Computational Aspects of Solid Mechanics
> > Professor, Department of Mathematics & Statistics
> > Hamilton Hall room 409A, McMaster University
> > 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
> > https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
